Franklin Automatic Adjustable Wedges
FLtenwheeler
Post by FLtenwheeler »
Hi All
Has anyone installed Franklin Automatic Adjustable Wedges on a model locomotive?
Tim
LivingLegend
Re: Franklin Automatic Adjustable Wedges
Post by LivingLegend »
Not that I know of. But the question is.... Why would anyone want to? All it does is automatically take up and compensate for wear on the shoe face. Something you don't really have to worry about on a live steam model.
LL
Do it right.... Or don't do it at all
I have no life. Therefore, I have a hobby
It's not that I'm apathetic, I just flat don't care
An Intellectual is nothing more than an Over-Educated IDIOT
Blogs: Where people with nothing to say..... Say it
LivingLegend
LivingLegend wrote:....But the question is.... Why would anyone want to? All it does is automatically take up and compensate for wear on the shoe face. Something you don't really have to worry about on a live steam model.
I should add....
My "why would anyone want to" statement applies to working automatic adjustable wedges. Franklin wedges, made as part of the frame/journal shoes in a dummy shoe assembly, would be a different matter. There are a few builders who have used shoes on their loco frames.... On frames having two straight pedestals, or one straight and one tapered per opening.
LL
Just something else to be broken, bent or ripped off in case of a derail.. :shock:
Bill Shields wrote:Just something else to be broken, bent or ripped off in case of a derail.. :shock:
And yet-----for a rivet counter---
LivingLegend
Speaking as a rivet counter.... I'd probably install, as per prototype, the shoes on the loco frame. That said, there are some parts, or parts in an assembly which, dependent upon the scale being modeled, don't lend themselves to being a miniaturized working piece.
If the pedestal shoes were to be left off an outside frame engine, such as a DRGW K36, their omission would stick out like a sore thumb to someone knowing their way around the design of a full size locomotive. Particularly, if the model was built to a larger scale.... Such as 2.5". In 3/4" or 1" scale or smaller? That's another matter.
LL
HEY...I count rivets like everyone else...I just count them differently..
Let's see, there are 100 holes to put rivets into and YUP, there are 100 rivets in the designated holes.
count is correct...
:shock:
LivingLegend
Bill....
The are four types of modelers.... Regardless of what is being modeled. (Be it railroad, stationary/traction steam, aircraft, marine, automotive, or whatever)
1. The modeler who strives for an accurately detailed miniature built as close as humanly, and practically possible to the original.
2. The modeler who builds to a close, but lesser standard of detail of the original.
3. The modeler who only cares that it represents something close to remotely resembling the original.
4. The modeler who doesn't care what it looks like. Anything near to, or anything like an original. (In the case of live steam.... It has wheels, a boiler, runs on steam, and is painted black. In the care of "diesel".... It has a frame, wheels, an engine/transmission to power it, and a plain rectangular wood box body to cover the inner workings..... That's all that matters to them.)
Let the builder build the way they want, in the way that suits what they want.
LL
hudson
Post by hudson »
slightly off topic:
Hannes Paling, a well known South African builder and photographer uses
(manually) adjustable wedges on his plate framed narrow gauge 0-6-0:
http://www.flickr.com/photos/alfav8/321 ... 827610727/
hudson
LivingLegend wrote:Let the builder build the way they want, in the way that suits what they want.
Yep. For some folks, the point is the journey, not the destination. Some are detail oriented, while others are detail blind.
There is no right or wrong. We each dance to the music we hear.
Asteamhead
Post by Asteamhead »
Hey all,
The question was if anybody has developed (and used) working automatic franklin wedges. If yes, this could be of interest for some life steamers (may be for us rivet counters exclusively). An inspiration without question!
Simple wedges which can be adjusted in tapered slots by means of a thread and locked by counter nuts are very easily to be added. With my A frame I use these just for the main axle (right), please look on the photo.
In combination with roller bearings they will improve smooth and even running - no surplus at all!
Just my two cents ...
Asteamhead
Wedges to be seen behind the main (right) axle. Bolt will be fixed by counter nuts from below.
Asteamhead
Some more pictures of my class 44, 1 in 10 scale showing some details
Asteamhead.
