I've never been able to even change a speed aside from a flat belt! lolwlw-19958 wrote:Hi There,
The first one looks like a 10" Logan. Unfortunately, it doesn't
have a QC gearbox and the through-hole in the headstock is
under an inch. Definitely not worth two grand.
The second is a WWII SBL Heavy Ten with a Single tumbler
gearbox. Generally they are good lathes but this one looks
to have considerable wear to the bed near the headstock.
WWII SBLs did not have bronze bearings in the headstock.
They used the cast iron of the headstock; segmented for
improved lubrication. Considering the wear, I wouldn't buy
this one.
Just two more cents. Good Luck!
-Blue Chips-
Webb
That is a 10" Logan, 45 minutes from my house and look at the tooling it comes with! Super clean.
Where are my logan fans. That SB has wear and has the bronze/lead babbit bearings, I'm done with those!
