Screw for Chinese Co-Ax Indicator Probe?
- SteveHGraham
During my recent adventure with the broken drawbar, my CDCO co-ax indicator fell out of the collet. I thought it was undamaged, but it turns out the tiny screw that holds the probe in snapped. The body of the screw is still in the indicator. I'm not worried about that, because it's very loose, and I'm sure I can find a way to turn it. But where am I going to get a replacement? I can't measure the threads because it's so small.
I guess I can go to a good hardware store and root through every small screw they have. I have a feeling the Chinese indicator company is not too excited about supplying parts.
- seal killer
Re: Screw for Chinese Co-Ax Indicator Probe?
SteveHGraham--
Is this your indicator? If so, here is the screw . . . I am not familiar enough with millimeter screws to tell you what it might be. Maybe 2.5 something? (If such even exists: M2.5?) My recommendation is, based on my picture compared to your broken screw, buy a bunch of teeny millimeter screws in an ordered sequence of size and use the one that fits.
--Bill
--Bill
You are what you write.
- seal killer
SteveHGraham--
My screw is 0.114" in diameter. That would be 2.8956mm.
--Bill
--Bill
- SteveHGraham
Thank you for the help. I'll bet it's the same. I'll run by the store on the way home from church tomorrow and get an assortment.
It would help a lot for people to buy one of every size metric nut and bolt while at the hardware store. That way you might have something to match up to when a metric fastener is needed.
- seal killer
SteveHGraham--
I'm bugged by your screwy problem. (Plus, I am HIGHLY bored.) I measured my screw at 0.114". The closest metric size is 3mm, which is 0.118".
Here's a table. Scroll down.
--Bill
--Bill
- warmstrong1955
I just measured mine. M3 x 0.5
I tested it in a die....too.
Bill
Bill
Can't help with your problem, but have to admit when I read your thread title, I thought, is he trying to buy one, or has he got another option.
James
James
- SteveHGraham
Desperation can be an ugly thing.
I take things apart and keep hardware. PC hard drives, printers, scanners, etc. have good usable components. Many screws too...
- tornitore45
We are affected by the same sickness. There is no cure.I take things apart and keep hardware.
Electronic hardware is full of small metric screws such as M3.
Hardware stores around here stop at M4.
Steve if you do not find a suitable replacement, I can send a plain SHCS or even make a knob for you. Just PM.
Mauro Gaetano
in Austin TX
in Austin TX
About 3 years ago Jose Riviera recommended a program called "Screen Calipers" (http://bit.ly/caliperIco). Using that program, and assuming your ruler is in metric, I believe that is a 3mm x 0.5 pitch x 5mm long metric machine screw. In that diameter, 0.5mm is considered coarse thread.seal killer wrote:I am not familiar enough with millimeter screws to tell you what it might be. Maybe 2.5 something? (If such even exists: M2.5?) My recommendation is, based on my picture compared to your broken screw, buy a bunch of teeny millimeter screws in an ordered sequence of size and use the one that fits.
Note: I measured the scale in pixels across 4 divisions, then calibrated by creating a custom unit, 4 of which were that number of pixels. This provides a fairly accurate set of calipers in scale with the displayed image. Until or unless you zoom in/out, of course. Then you have to recalibrate again. A handy piece of software, well worth the $10 over the years.
