The funny thing with this lathe is the spindle has the A1-5 mount, but doesn't have all the drilled and tapped hole it should have. I thought that was an odd thing for a lathe manufacturer to do! So you just can't go and get any A1-5 chuck to mount, because you are limited to using the adapter plates. Still a real nice lathe even with some of its unusual features. Now if you were to drill and tap the needed holes in the spindle then a whole world of options open up.
It is in fact a A1-5 as there are four allen headed bolts holding the back plate to the spindle. The notch in the side of the chrome ring is to allow the bolts to be removed from the plate by lining them up with the notch.
So I assume now to fit a faceplate or four jaw cuck I need to find them and machine the backs to fit the plate and then drill and tap for the bolts.
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
The backplate should stay with the chuck and any other accessories should fit the bare spindle. Each chuck should have its own backplate and faceplates are generally machined to fit the spindle directly without a backplate. It is certainly possible to use a single backplate with multiple chucks, faceplates, etc., but I have never heard of anyone doing it that way. You would have to machine the back of each chuck and 4 jaw chucks generally take a different style of backplate from 3 jaw chucks. The common interface point should be the bare A1-5 spindle.
Have you found the manual yet? I had the same problem finding one for my newly acquired 1236PS So I called them (I think 1.800.274.6846) and asked expecting to have to pay for it. She emailed it free! Hopefully that will work for you.
If memory serves there was a little confusion as to which I needed so she sent all that she thought might be applicable and got me the manual.
Thanks for the input. I have not found anything on the lathe to date. I will give them a call next week. I assume I will need the model and seriel number handy when I call
Luck is with me though as everything seems to be there and it all works. I have made a few small parts on it but have been holding off till I could get it all leveled up and clean it.
I have had a couple of people ask about buying it but to be honest I like having it in the shop. It gives me a backup and also has a different capability having the gapped bed.
I have set it behind the Southbend and split off my three phase to it and a Bridgeport.
The idler motor is under the Southbend and fairly quiet.
Charlie
Charlie Pipes
Current Projects:
I have a Manual for the JET 1430 Engine Lathe with specifications; and if anyone is interested in obtaining a copy, I can be emailed at nmaccara@jetgroupbrands.com and I will scan and email you the manual
It's years old, but in great shape for emailing
Also a parts list for a JET 1024 Bench Lathe with specifications
Charlie I think I know what you meant when you mentioned "sanding it down", but just to be 100% clear you were talking about the painted areas correct?
And Nancy at Jet, that certainly shows some excellent customer service on your part. That's more than rare today even though emails are so much easier than snail mail was, yet company's were still willing to do the same as you have before computers. Any chance of your bosses email address so I can let him know how impressed I am? If you'd rather you can send it in a pm to keep it off the net.
