I was preparing for Valentines day (although I'm unsure if my machine will be ready in time). I created this code block that can be run on a 1" round bar stock stood vertical in the mill, with center at 0,0. It uses about 1/2" of stock, which can then be parted off in the lathe. There is about 0.4 x 0.2 flat for engraving if desired.
The formula for the outlines:
x=16sin^3(t) (Edit: this is supposed to be the value of sin cubed.)
y=12cos(t)-5cos(2t)-2cos(3t)-cos(4t)
where t is an incrementing angle (0 to 2pi). I am incrementing in 0.1 radians per code line to generate each curve. Each curve is reduced in "diameter" by a 2nd order function as Z is raised 0.050
Note that none of the tool or machine setup is included and I have only run the program in a simulator. I imagine a 1/8" ball end mill would make a usable shape, but I expect there would be stepping (kerfing?) lines. If anyone runs this, let me know if it needs any tweaks.
G-Code Love
G-Code Love
- Attachments
- g-code-love.txt
- (70.69 KiB) Downloaded 531 times
Re: G-Code Love
In math, what does:
x=16sin^3(t)
mean?
Looks like you are raising something to a power, but you can't raise SIN to a power, as it is only a function not a value.
x=16sin^3(t)
mean?
Re: G-Code Love
SteveM
to me it must be a typo, I would think the equation isn't raising the sin to a power its simply 16 times the sin of the value of 3 times (t), where t is the incrementing angle
or 16(sin(3t))
or 16(sin(3t))
Rick
“We make a living by what we get, but we make a life by what we give." Sir Winston Leonard Spencer Churchill (1874-1965)
"Peace is that brief glorious moment in history when everybody stands around reloading". Unknown
Murphy's Law: " If it can go wrong it will"
O-Tool's Corollary: "Murphy was entirely too optimistic"
Re: G-Code Love
Steve, it is the value of sin(t) cubed. I did not want to confuse raising t to the third power.
x = 16 * (sin(t))^3
BTW, I have to replace the g-code txt file because it will make the initial outline at full depth and break the cutter. I think I can step the outline down in 0.050" increments from the top, and then step back up and inward for each subsequent layer.
x = 16 * (sin(t))^3
Re: G-Code Love
Here is an update. Same file as first one for the boss, pocket attached here. I just ran it a couple times and raised the knee...
- Attachments
- heart-pocket-01.txt
- (48.73 KiB) Downloaded 516 times
Re: G-Code Love
Hi ctwo,
Very nice. I'm impressed.
Richard Trounce.
Richard Trounce.
Re: G-Code Love
I am working on another. Here's the rub - my software no longer works on the recent Win10 Creators update. Well, I'd be learning all over again anyway... also, I want to cut the outside shape as well, so working on a good way to hold the work piece and then get rid of the holding stock... AND I want a better hinge.
Re: G-Code Love
OK, here is an idea:
The piece will be 1" finish height (0.155" thick lid and 0.845" body) and 1.625" tall and wide. I will use oversize 2" round stock faced to 1.2" long, then flats on opposite sides, 0.100 deep. That will give me a flat surface to grip in the vise.
I will mill the body OD and pocket first, then I can flip it over and mill the lid OD and engrave, leaving the extra holding stock closer to the lid. I've determined that the shape will grip fine in my 3-jaw chuck, so I will part the lid off through that stock and have about 0.050" to face off each piece. The body should be strong enough since there will be 0.155" solid at the bottom of the body. It will be beautiful!
I also think that I will counter bore the lid to use a small cap screw for the hinge, and maybe even make a plug to hide the hole..
