Building a locomotive from erection drawings
Hi Everyone,
Some time in the future I would like to build a Northern Pacific A-3 4-8-4 in 7.5 gauge. The good news is this locomotive is almost identical to the SP&S 700 up in Oregon. The bad news is, so far I have only been able to find erection and section drawings for this locomotive. I contacted the president of the SP&S 700 group, and although they do have some drawings (not sure which or how many), they were very reluctant to allow me any access or reproduction of them. So that leads me to my main question. How feasible is it to build a locomotive completely from erection and section drawings? Any insight would be greatly appreciated.
Thanks
James
Thanks
James
Re: Building a locomotive from erection drawings
James
Sounds like a neat project, there are 2 guys out in California that are using my big ALCO Northern chassis and parts to build a engine that is close to the 700, they are making there ouw kink girders and other valve gear parts but are using our tried and provien prints and chassis components as well as tender trucks
contact me at Little Engines if you need more information
Mike
Mike
James,
It can be done. I'd recommend 3d CAD. That said, you would save a considerable amount of time and money by using available parts from the many vendors that support the hobby. Incorporate them into your 3d work.
Alco Historic Photos should be able to supply you with builders photos and maybe Paster cards
The Northern Pacific Historical Society has a downloadable spreadsheet of the 485 assorted drawings in their collection
Jerome Simon - a member on this group - is doing that same thing you are attempting to do - only for BLW Frisco 1522. He used to have a nice web page up - but I can't find it now. The site detailed how he sourced all of his cast parts prior to making any chips.
Warning - even if you had the several hundred drawings you'd need to build the real loco, a lot of the smaller parts - and a bunch of the bigger parts - just don't scale down that well. Many of the smaller parts are not even used by live steam modeler.
Start figuring out what items that alco used on other locos and then beat on those sources. Look at other 4-8-4s made by alco.
Most of the societies are more cooperative. Heck NYC and UP and others offer the drawing sets of CDs.
Please contact me off site at mark_landgraf at yahoo dot com I can point you to some other resources.
Mark
Mark
question:
have you built a model steam locomotive?
Bill,
I have not build a locomotive before. I understand this is a very complex locomotive and that it will add to the difficulty. I also understand by not building from a kit it will increase time and difficulty as well. However I only plan on building one locomotive, and I would like to build the one I want. This will be a long project.
Thanks
James
Thanks
James
What happened to your 3.5" gauge little engines 4-8-4?
My site is temporarily down. The webhost company had something go wrong with their server and I think my site was lost in the fray. I just noticed it this morning. Hopefully it will be back soon. I have everything backed up so I'm not worried. To note, I had to set the project to the side while I am doing some basement reconstruction. I hope to be back on the project by mid summer.Jerome Simon - a member on this group - is doing that same thing you are attempting to do - only for BLW Frisco 1522. He used to have a nice web page up - but I can't find it now.
I would second trying to use as many parts off the shelf that you can find. It will almost assuredly save you time, money and headaches. Plus you'll be supporting the vendors which is probably the best reason of all. If you can use some of the Little Engines parts I would definitely use them. Mike is great to work with and extremely helpful. If I was unable to secure the parts I was looking for in order to build the Frisco 1522 I was ready to order his ALCO hudson parts and to build CP2816.
James, even though you have not built a locomotive before....do you have experience with machine tools? You will need some skills in precision metal working. If you don't have that background, you should look into a night school or meeting with club members who might be willing to teach you.flyguy wrote:Bill,
My second piece of advice is to build the tender first. The tender project will give you experience in machining, sheet metal work and working to a design. It has the added advantage of allowing you to test your locomotive once it has reached the stage where it can run. It is no fun to have started building the locomotive first and getting it to a stage where you can test run it....and then have no way to get fuel and water into it!
Best of luck!
Keith Taylor
James
here is a picture of an ALCO Northern chassis built from off the shelf castings
you would need to make different girders and link hangers but that is easier than trying to build from dead scratch
Mike
Little Engines
Mike
Little Engines
Hi Everyone,
I am definitely planning on modeling the locomotive in a 3D CAD program to make sure everything fits as it should. And I will definitely use as many off the shelf parts as possible. Just a little more background information, I am currently taking some machining classes at a local college. It has been very informative, and although it can't possibly cover everything involved in locomotive production, its a good start. After I finish with my machine shop classes I will go on the hunt for some decent machines. I will be looking for a full size mill and a good sized lathe ideally 14" or greater.
I would like to make the locomotive as detailed and prototypical as possible. My thoughts were to start off by getting the Little Engines Alco Northern plans and thoroughly reviewing them. I will try to incorporate as much of that design as possible. One of the things that has always been a mystery to me is determining the appropriate clearances. I would assume the prints would help clarify some of this.
The engine definitely needed some work. Its coming along nicely though. Ill update my original post about it soon.
Thanks everyone
Builder01Builder01 wrote:What happened to your 3.5" gauge little engines 4-8-4?
Thanks everyone
Mike...
GASP....is that a drawing board with a Drafting Machine I see in the background?
Giggle....
Giggle....
...Why yes it is Bill...thats Paulies 2D MAD (Manuel Aided Design)...LOL
