CNW J class Mikado
FLtenwheeler
Re: CNW J class Mikado
Post by FLtenwheeler »
JohnHudak wrote:
FLtenwheeler wrote:Hi Harold
I use silicon bronze ingots for locomotive parts. I have been using Shapeways "White Strong & Flexible Plastic" for the wax. (LOL) I am having very good luck.
Tim
The white plastic burns out just like wax..? Doesn't shapways print in wax also?
John
Hi John
Yes, the plastic burns out clean, but it does stink. Luckily the work shop is not attached to the house. The Shapeways wax is for small objects and is very costly.
Tim
FLtenwheeler
I was able to get some work done on the drivers. The axle hole is bored and reamed to size. Now to cut the keyways.
Tim
kvom
Post by kvom »
Tim
John
The wax is much more expensive than the plastic. Plus, you can make only small parts in wax.
Fender
Post by Fender »
Very interesting, Tim. What temperature do you use to burn out the "lost plastic", and for how long?
Chattanooga, TN
FLtenwheeler
Hi Dan
I use Ultra Vest Jewelry Investment With Fiberglass and use there standard burnout instructions. So it is 1350F.
Tim
FLtenwheeler
I have the driver centers machined and am working on machining the tires. I am going with an 0.008" shrink fit. I am trying to hold a plus or minus 0.0005" on the tire ID.
Tim
FLtenwheeler
Hi All
I just received the Frame Crosstie & Bumper Beam Bracket from the foundry. It turned out great. A printed sand mold was use to produce the casting. I am very happy with the results. How to set it up and machine it. Then I can assemble the side frames.
Tim
Frame, Crosstie & Bumper Beam Bracket
Jerry_H
Post by Jerry_H »
It's a work of art, Tim.
Jerry
www.chaski.com
FLtenwheeler
Kimball McGinley
Post by Kimball McGinley »
Is that George Washington your change back from a Ben Franklin?
Post by Glenn Brooks »
FLtenwheeler wrote:Hi All
Tim
Hi Tim,
This is very interesting! How complicated a process is it to have the foundry create the printed sand mold and make the part?? Is it expensive to create small batches of one off parts, such as 3" scale frame pieces, couplers, etc for a 12" ga loco???
Thanks much
FLtenwheeler
Kimball McGinley wrote:Is that George Washington your change back from a Ben Franklin?
I wish. It was a lot to get this part done. I need to learn how to gate and do the mold setup myself.
Tim
