New member
schwinncoll
Re: New member
Post by schwinncoll » Mon Nov 14, 2016 4:48 pm
I'm sorry Marty, I should have specified. The tender brakes are the ones that are off. One truck is applied while the other is released and then when you release the one the other is applied. I'm thinking its the wrong pivot point.
Re: New member
Post by Bill Shields » Mon Nov 21, 2016 8:12 pm
brake rigging is here:
http://www.mehrs.com/misc.html
it is shown for a 2-8-0 but the idea is the same for other arrangements
jscarmozza
Re: New member
Post by jscarmozza » Mon Nov 21, 2016 9:24 pm
Does anyone have drawings for a brake rigging system with two shoes per wheel? I see from NP317's drawings that I got mine all wrong, should have asked! Any help would be appreciated. John
johnpenn74
Re: New member
Post by johnpenn74 » Tue Nov 22, 2016 8:43 pm
An easier way to fabricate the brake beams parts is by using commercial clevises and steel brake beams closer to prototype beam sizes ( should be about 1.5x 5 on the prototype). All of it should be assembled with pins and cotters. The 1/2 x 1/2 is way over scale but also requires you to fabricate a lot of slots, and places to attach the custom machined celvises and allow the rods to pass through. If you stick with commercial clevises (Recycled a few on the engine, bought the balance from mcmaster) they will have enough length in the clevis to pass over the short equalizer link and attach to the brake beam with a pin. Which is like the prototype in appearence, functionality and size. Truth is the prototype never used threaded rods or clevises, usually was a cast or forged rod. As much as I don't like the aluminum brake beams they will work fine as they don't really have that much load on them. Or a better option is to start with 3/16 x .75 x beam length and turn the pins on the ends instead of threading shoulder bolts into it. Tapped holes are usually non prototypical and evil, but that's for another thread... Also, think twice about putting the connecting links directly under the main frame, where they pin into the beam. Makes it real difficult to get the pins out for maintenance. Will post pictures when I find them.
JP
M&B 444 brake equalizers
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
schwinncoll
Re: New member
Post by schwinncoll » Wed Nov 23, 2016 7:14 am
Anyone have photos of the brake rigging on the tender? The brakes on Warren's Mogul are backwards. When one truck is set the other is released and vice versa.
Marty_Knox
Re: New member
Post by Marty_Knox » Wed Nov 23, 2016 7:24 am
Allen never provided tender brakes. You will probably need to get a prototype freight car rigging diagram.
johnpenn74
Re: New member
Post by johnpenn74 » Thu Nov 24, 2016 10:42 am
SchwinnColl,
Post a few pics of the brake linkages to the group and I can tell you what to change. Should look something like the attached.
JP
John Shucks Allen Mogul
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
