Well, you live and learn. I tried this before reading your reply and, yep, that's what happened. Surprisingly, the tool didn't break but it did ruin the next piece inboard. Sooooo, I just parted the last few pieces without the threaded rod. Then, chucking up the all thread, threaded two of the pieces onto the rod, using one as a jam nut, the piece I was working on slightly hanging off the end, I was able to face and chamfer it. Only problem was I was unable to get the all thread turning true in the four jaw.GlennW wrote:When the parting tool breaks through the brass part it may grab it and tighten it on the threaded rod pinching the parting tool.
Here's the final result. Thanx for all the advise and help.
John
