Romulus build
Fred_V
Re: Romulus build
Post by Fred_V »
Ash Tuesday. Ash pan that is. Wed. I'll add the damper to the rear. The short lines that are brazed are cut lines. This allows me to make bends by hand since I don't have a heavy duty brake.
Fred V
Pensacola, Fl.
Fred_V
Re: Romulus build
Post by Fred_V »
Busy day today, ashpan finished, injector plumbed, axle pump plumbed, pressure gauge fitted and a footplate and water control valves fitted.
Big day planned for Saturday. I'll take Romulus to the local track for a test run!!! I don't have a tender so I'll run plastic tubing to a bucket of water. It will be fun. Oh, I finally got the lubricator primed. Had a fussy check ball and wouldn't pump. It does now.
check out the injector. That is an Enos Yoder original design; a very talented builder.
I hope to post a video on Sunday.
Fred V
Pensacola, Fl.
Builder01
Re: Romulus build
Post by Builder01 »
Good going! Have fun on Saturday! Keep us posted!
David
Soot n' Cinders
Re: Romulus build
Post by Soot n' Cinders »
That injector is funky looking. Im curious to see how well it works, looks like one of those fluky British designs in the picture but that says nothing of the internals
-Tristan
Projects
Fred_V
Re: Romulus build
Post by Fred_V »
He said it works well and that Enos had built many of them. It is very nicely made and by the size of the cones should put out a lot of water. I don't know how it would respond to hot water as in a saddle tank engine.
Enos is quite a craftsman and has built 16 or so engines all of the style in this photo. Nice looking engines.
Fred V
Pensacola, Fl.
Pontiacguy1
Re: Romulus build
Post by Pontiacguy1 »
That locomotive looks familiar... at least parts of it do.
Fred_V
Re: Romulus build
Post by Fred_V »
Scott, this one showed up at Mid South a few years ago. This guy built it from Yoder drawings.
Fred V
Pensacola, Fl.
Fred_V
Re: Romulus build
Post by Fred_V »
Sat. was a success, the engine ran great!! It took some debugging and 3 fireings before all was well and I was able to get on the track. I had to run it on the axle pump but that was fine once I got the air purged.
https://www.youtube.com/watch?v=hE1orBJ ... e=youtu.be
Fred V
Fred V
Pensacola, Fl.
Builder01
Re: Romulus build
Post by Builder01 »
Congrats! Nice video. Your coal shovel is pretty fancy!
David
Fred_V
Re: Romulus build
Post by Fred_V »
Today I fixed bugs from the Sat. run and made brakeshoe hangers. Linkage Tomorrow.
Fred V
Pensacola, Fl.
Kimball McGinley
Re: Romulus build
Post by Kimball McGinley »
Can you tell me about those brakeshoes? I am looking for some like that!
Fred_V
Re: Romulus build
Post by Fred_V »
Today I made the brake shaft and the drop links that hang on it. Also made the manual knob for applying the brakes and the big nut that connects it all together. Long day but lots got done. Just need to make 4 clevises and the connecting rods to tie it all together. These brakes apply via compression rather than compression and are only on the rear axle (per the prints). I did do a different kind of actuation method. But:
That's the brakes!!
Fred V
Pensacola, Fl.
