Repinng turret on a CNC lathe
Machwright
Post by Machwright »
Have an idea of how to do it. But taper pins to housings are oval and someone in the past has redrilled relocation holes in ring gear. Any thoughts out there.
Bob D.
Re: Repinng turret on a CNC lathe
Post by Bob D. »
Not knowing what you have for a machine.......Generally location pins are used to set the turret face in alignment. The locking bolts are cinched down and the pins are removed. That way in a crash the turret can slip and not damage anything other than alignment. If these locating holes are damaged from leaving the pins in, than it is not uncommon to abandon them and drill & ream new ones after the turret is trammed in. You really don't need the pins. They just make realignment faster.
A Coaxial indicator makes tramming pretty easy.
Bob D.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
A PICTURE or two of what you are facing will help us understand your situation
