LOUD diesel horns?
LOUD diesel horns?
Hi,
I just acquired a 2.5 inch switcher loosely modeled after the D&RGW # 50. Currently it has what I would call a generic Wal Mart horn. Medium loud and kind of flat. Looking to replace it with something that is a little louder and attention getting. Room is not a problem and there is a 12 volt system with an automotive battery, so current is not the problem either.
Just wonder what other operators have come up with?
Dick
Dick
- Atkinson_Railroad
Re: LOUD diesel horns?
The Italian made Stebel is a very good horn.
You can hear what various models sound like here:
http://www.stebel.it/stebel/products.as ... PNEUMATICS
Pricing info can be found at their USA website:
http://www.stebel-usa.com/product/38/mo ... ompressor/
If you go the economy route choosing something from an auto parts store, there’s a good chance you’ll be disappointed.
John
John
- makinsmoke
Hi Dick,
Unless you have air on your loco you are stuck with electric. With 12 volts auto or truck horns
are easy to find.
Do a little research and find out what the 50
had on it in the way of an air horn. Once you have that you can find out the frequency of the air horn and buy a 12 volt horn of the same frequency.
You can find little 12 volt compressors but the trouble is finding a decent air horn. Either they are European type high pitched jobs or regular diesel or locomotive horns. In either case no one will want to spend the day around you yanking
on it. And you'll be deaf as well!
Take care,
Brian
are easy to find.
Take care,
Brian
+1 for adding a small air pump and maybe a holding tank. Also, I read somewhere that diesel RR horns were multi chime. Meaning the RR's mounted three to five horns, each with a different pitch, in a bundle on the cab. So you get a sweet, distinctive, multi chime sound. You might consider finding two or more horns and combining with your existing flat base horn to produce exactly the right sound you are looking for.
Two suggestions.
First suggestion.
Go to a automotive recycling yard and hunt for the horns off of something like a Regal or other luxury car. They sound rather nice, although a bit more like a boat horn than locomotive in my opinion. You need to get all 3 or 4 horns though for the nice sound, and they are well hidden.
Second suggestion.
Harbor Freight has a 3 chime air horn set with compressor that doesn't sound too bad, especially if you have your own compressor to supply the air.
Karl
First suggestion.
Second suggestion.
Karl
I'll second the Stebel horns. I have a "nautilus truck horn" that is a single note at 300hz. It's real close to one of the WABCO single note hooters that Baldwin used on their early switchers. It's loud enough but not "kills your ears" loud.
Check the frequencies and you could mix or match two different 2-note horns and come up with a good sounding horn.
Darren McNeely
and the sons of Pullman Porters, and the sons of engineers,
ride their father's magic carpets made of steel.
www.swlsonline.org
www.swlsonline.org
300 Hz is too high, approximately E♭ above middle C. The WABCO horns used by Baldwin were about a major sixth lower in pitch, which would put the frequency around 195 Hz. The honkers used on E- and F-units, as well as the GG1, are even lower pitched, around a D below middle C and thus around 140 Hz.slsf1060 wrote:I'll second the Stebel horns. I have a "nautilus truck horn" that is a single note at 300hz. It's real close to one of the WABCO single note hooters that Baldwin used on their early switchers. It's loud enough but not "kills your ears" loud.
Really a shame acoustics don't scale...
300hz works for me. Like I stated, it's close. And I'm not going to have a 2 plus whatever foot horn bolted to the top of my diesel...BigDumbDinosaur wrote:300 Hz is too high, approximately E♭ above middle C. The WABCO horns used by Baldwin were about a major sixth lower in pitch, which would put the frequency around 195 Hz. The honkers used on E- and F-units, as well as the GG1, are even lower pitched, around a D below middle C and thus around 140 Hz.slsf1060 wrote:I'll second the Stebel horns. I have a "nautilus truck horn" that is a single note at 300hz. It's real close to one of the WABCO single note hooters that Baldwin used on their early switchers. It's loud enough but not "kills your ears" loud.
Darren McNeely
www.swlsonline.org
www.swlsonline.org
Hella makes a set of electrics that pair a 420hz with a 300hz, has anyone tried the 300hz by itself? Could mounting it within a chunk of ABS pipe deepen the tone? I was thinking of trying that and pointing it at the ground. Maybe only one way to find out...
I'm trying to shop for a horn for my Baldwin S-12, and because I don't want to tick off the neighbors I'm looking for something not all that loud...just enough that if I'm crossing my driveway and someone is there I can wake them up a little:)
I'm trying to gather everything that will mount within the body, as I'm going to start sizing the fuel and hydraulic tanks soon and they are going to take up most of the remaining space.
Aren't there also all-electric sound systems made? I mean, something that has a digital recording of a real loco horn. All you need then is an appropriate speaker.
I made an ------ loop player for my 24 foot boat. It has a clip of a BIG ferry horn and when I blow the horn, everybody is looking around for a monstrous BIG ship! They work GOOD!Kimball McGinley wrote:Aren't there also all-electric sound systems made? I mean, something that has a digital recording of a real loco horn. All you need then is an appropriate speaker.
Go to junk yard. Find a 1970-80’s Cadillac. Caddie have two horns, one high, one low. You will find them on each side of the engine compartment. Guaranteed to scare someone when you hit the button....
Christopher P. Mahony
Los Angeles Live Steamers
1 inch scale member
1 inch scale member
