Injector
Trainman4602
Re: Injector
Post by Trainman4602 »
I think Amazon has them beat
jma1009
Re: Injector
Post by jma1009 »
Hi Greg,
Your pic of your 'D' bit 9 degrees tapered reamer looks to be considerably greater in degrees than 9. What is the OD and what length is the taper?
I have not found any engraving bits of small enough taper but I do use them sometimes to remove some of the metal before using my injector reamers. The engraving bits have a tendency to chatter because one side has a different taper to the other in effect providing rake on the cutting edge.
Cheers,
Julian
Greg temp
Re: Injector
Post by Greg temp »
Hi,Julian,yre wright,the angle is steeper than 9 degrees I made a technical error.it came out at 14degrees,put it down to being too late at night,the shank size is 1/4inch,
That one is now in the bin,remade two (the correct angle this time) last night,
Thanks for the heads up on the deburs,
It's better to try and fail than not to try at all,
Trainman4602
Re: Injector
Greg
Where are you getting all these angles from?
Greg temp
Re: Injector
Post by Greg temp »
I got the working drawings for a 40oz injector I need to make a 9deg and a 13 deg Dbits,I just stuffed up setting my compound slide on the first one I made,but still a good training excersise
Builder01
Re: Injector
Post by Builder01 »
If you are reading the numbers on the top slide angle graduations, or, compound, make sure you understand the difference between the angle on the side of what you are machining, and "included angle". Also, make sure your tool is exactly on center height, or, the surface you machine will not be a true taper.
David
Greg temp
Re: Injector
Post by Greg temp »
The problem I had was I just miss read the increments on the compound slide,and the tooling is dead center,
Builder01
Re: Injector
Post by Builder01 »
Okay, keep us posted on your progress. As you can tell by the number of posts, many are quite interested.
David
Greg temp
Re: Injector
Post by Greg temp »
Update on progress,,,D reamers and depth guages done,
Just waiting for the brass to be delivered,will start on the body in the mean time,
Greg temp
Re: Injector
Post by Greg temp »
Update for those interested,the body is made ,start on the cones this week,
I will post some pictures once I can get them small enough insize to post
Greg temp
Re: Injector
Post by Greg temp »
The complete body,just the nuts to make then start on the cones.
The body
The body
