Coppersmithing a Boiler - Southern Railways Bulleid Pacific
Re: Coppersmithing a Boiler - Southern Railways Bulleid Paci
AusDan wrote:absolutely fantastic...before to many posters turn up, you could reply several times leaving the post blank and then insert the continuation as you go so all the thread is on the 1st few pages... :)
A very considerate thought. So much so that I will delete your comments so they do not interrupt the thread.
Thank you for the consideration, and please excuse my having deleted your very welcome comments.
edit: corrected spelling
Andrew Pugh
Post by Andrew Pugh »
tsph6500 wrote:Updated
Any chance you could post a pic similar to boiler 24 but showing the results of the silver solder job?
Thanks,
Andrew
UKlocoNut
Post by UKlocoNut »
View of tubeplate after soldering & pickling
View of tubeplate inside firebox
Hope this is ok
Keith Wood
MLS
Mike Walsh
Post by Mike Walsh »
I notice that the builder is using "bridges" between the crown sheet and the boiler barrel/top of boiler. Is this to eliminate the need for staybolts? Could one get away with this on 1" scale locomotives?
Just curious, as I'll be reaching a point that I can start developing the boiler for my 2-8-0 soon!
tsph6500
Post by tsph6500 »
tsph6500 wrote:Boiler Building - Final Installment
by Keith Wood » Sun Dec 05, 2010 11:56 am
This episode - Boiler Testing.
Updated and the series is complete. Now get some copper and start bashing away! :lol:
Best regards,
Jim Leggett
Montreal Live Steamers
www.montreallivesteamers.org
A Founding Member of the Tinkerbell Scale Society - Northern Division
I'm an A.R.S.E. (Association of Railroad Steam Engineers)
Toad Swamp & Punk Hollow Railroad - Head Tycoon
The Juvenile Traction Company - CEO & Apprentice Machinist 3rd Class
White Mountain Central RR - Engineer & Fireman
tsph6500
Post by tsph6500 »
Best regards,
Jim Leggett
kenn
Post by kenn »
Hi What's the chances I could get a copy of the cad model of this boiler I am busy modeling a B1 LNER loco in solidworks and I am battling. The model may help me get mine right
WJH
Post by WJH »
Ah the chain drive Bullied! What was their service record? Did they have maintenance issues? Looks like most of the internals were bathed in oil. Does your friends Bullied have the same chain drive or is it simplified? Thank you for the very nice forum posting!
tsph6500
Post by tsph6500 »
RB211 wrote:Does your friends Bullied have the same chain drive or is it simplified? Thank you for the very nice forum posting!
It is chain driven as per the prototype but he uses a total loss oil system rather than a bath. It runs very well, goes like the wind and has run at Waushakum LS in 2011 and its home track in Montreal. The build time was 2½ years.
Best regards,
Jim Leggett
Majorklein
Re: Coppersmithing a Boiler - Southern Railways Bulleid Pacific
Post by Majorklein »
So if one was to make a larger version of this boiler, would the thickness increase as well with the size if the pressure remains the same?
You need to define LARGER before you can get a meaningful answer....
BClemens
Post by BClemens »
Majorklein wrote:So if one was to make a larger version of this boiler, would the thickness increase as well with the size if the pressure remains the same?
Logically the answer would be 'yes' but: the tensil strenght remains the same so increased pressure (for a given material) would require increased material thickness proportinate to increased pressure.
A baloon will burst when the material thicknes cannot sustain the pressure or the tensile strength of the baloon material.
