Allen Models need info.
So we had a good response to the 0-4-0 and the FN 2-6-0 and the 2-8-0 frames. So now I am going to get the Mogul 2-6-0 , Ten Wheeler 4-6-0 and the American 4-4-0 frame done in a month or so. Just wondering the response out there for these. Please submit your post here and what engine you what your new Water Jet frame to be. Price will be the same 300.00 plus 45.00 for shipping. We have plans for machining of them. Drill and tap holes.
Example
4-6-0 Ten Wheeler Frame only one set.
Name and address if you wish. Just zip code.
Thank You
Steve Alley
Allen Models of Nevada
New Waterjet Loco frames.
Re: New Waterjet Loco frames.
I'd like a Mogul 2-6-0 frame, one set.
Jon Myers
Thank you for continuing to support this product.
Jon Myers
For those out there look at the water jet frames. New addition to the line.
M100-2 2-6-0 Water Jet Frame price at $320.00 New Mogul Frame Two on hand only.
H100-2 2-4-0 Water Jet Frame Price at $280.00 This is a new engine we are adding to Allen Models. It a 2-4-0 call the Harpur. Do to that is who made it first and Gene did not added it to the list of optional engines. Its a 2-6-0 Mogul less one drive axle set. Take all the casting that the Mogul takes but offer with only a water jet frame. Yes you can use the optional Wabash front truck to this. All parts in stock. Two on hand only.
T100-2 4-6-0 Water Jet Frame Finally the Ten Wheeler Price at $380.00 Two on hand only.
CO100-2 2-8-0 Water jet Frame Consolidation is back in stock. Two only in stock.
So if you what one and under the tree, Tell the wife and get yours now.
