Anyone in the Rochester, NY that can help someone?
neanderman
Post by neanderman »
A gentleman I know is rebuilding a 1923 Model T Ford, and needs the commutator on his generator turned.
PM me if you can help.
Thanks!
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Conrad_R_Hoffman
Re: Anyone in the Rochester, NY that can help someone?
Post by Conrad_R_Hoffman »
Well, I'm in Canandaigua, and have a small lathe. Doing a commutator properly (and I don't know much about it) also requires undercutting the mica or whatever they used for an insulator. There are/were accessories for that, but I don't have such. If he can describe exactly what he wants done, I might be able to help. OTOH, going to a specialty place that does generators for a living might be a smarter option.
Conrad
neanderman
Thanks, Conrad. I've let him know and will let you know what he says.
Ed
Atlas 618
neanderman
Conrad, he was able to find someone in Rochester.
I appreciate your willingness to assist.
Ed
Atlas 618
Ironman1
Post by Ironman1 »
For reference, when I was young, there were no alternators. So generator repair was very common.
I have seen homemade jigs to turn a commutator on the car, they clamped to the gen shell.
To undercut mica, which has to be done after turning, it was common to use a hacksaw blade. You ground off the set on each side of the blade so the teeth were there but no clearance angles. Then you hand dragged it in the slot between bars to remove mica, usually to about .030 thou depth.
Formal education will make you a living;
Self education will make you a fortune.- Jim Rohn
"Opportunity is missed by most people because it is dressed in overalls and looks like work." Thomas Edison
neanderman
Thanks, Ironman1 -- that sounds like a neat trick.
Ed
Atlas 618
