Where can a modeler purchase small scale pipe fittings and unions. 1/8"-3/16" sizes.
Has anyone taken over Coles or American Model?
Jeff Smith
small scale fittings
Reason: To correct subject matter
Re: small scall fittings
American Model is still in operation under new ownership. Wayne Godshall in Pennsylvania has taken it over.
Eccentric Engineer makes some great ones. But only down to 3/16" I will be in the market for some 1/8" and 5/32" fittings myself. Maybe we can get Anthony to do the smaller ones at some point. He is making the 2/3rds size injector for the 1" scale locomotives.jeffsmith wrote:Where can a modeler purchase small scale pipe fittings and unions. 1/8"-3/16" sizes.
Jeff Smith
Tim
PM Research has 3/16. Otherwise, you might have to go to the UK for smaller ones. Steamfittings.co.uk has a few in 1/8 and 5/32 for instance, and there are probably other suppliers as well.
JerryK
JerryK
Jeff, as mentioned before, Eccentric Engineer makes fittings down to 3/16, Live Steam Warehouse makes fittings 1/16 thru 5/16. I have seen both manufacturers fittings in person. They are of very good quality and appearance. American Model Engineering advertises MTP unions in their catalog. Attached are their web links below.
Vic
https://livesteamwarehouse.com/
https://www.eccentricengineer.com/
http://americanmodeleng.com/id33.html
Vic
For Duty and Humanity
- AnthonyDuarte
I do plan on adding 1/8" fittings to the line next time I send off waxes. The next round of castings will also include reducing elbows and reducing couplings.
Estimating February at the moment.
-Anthony (EE)
-Anthony (EE)
