Set of 24 2.5" scale bronze coupler castings ****SOLD****
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Harlock
Post by Harlock »
This is set of 24 Dave Skagan 2.5" scale bronze coupler castings.
I will prioritize buyers of the complete set before parting out.
They are deburred / deflashed and ready for machining.
$960.00 for the lot.
I also have a machined pair I will post separately.
I can ship these at your expense, or deliver to LALS or SBLS this weekend, Oct 7-8.
This is part of a larger tool and part sale:
http://gallery.mikemassee.com/-/galleri ... -tool-sale
-Mike
Re: Set of 24 2.5" scale bronze coupler castings
Post by Glenn Brooks »
Hi Mike, Interested in your lot of 2.5" bronze couplers. Any idea how compatible these would be with the RMI couplers?
Harlock
Post by Harlock »
The machined coupler set I had would not mesh with an RMI coupler, but should be fine with Artzburger couplers. The RMI couplers are kind of their own thing. 2.5" scale has an even bigger problem with coupler compatibility than 1.5" scale.
Harlock
Post by Harlock »
Price lowered to $800.00.
Mountaineer
Post by Mountaineer »
Has anyone used these type of couplers with Artzberger's?
Mountaineer
Harlock
Post by Harlock »
Mountaineer wrote:Has anyone used these type of couplers with Artzberger's?
Mountaineer
A preliminary fit check shows that they should work with Artzburger couplers. (I have an artzburger coupler on my engine.) You should machine one and test it and adjust as necessary before machining the rest. Should be quite flexible to modify depending on your pin design and other adjustments to the fit. The fit is tighter than a skagan <-> skagan connection but otherwise workable in my opinion.
Harlock
Post by Harlock »
BClemens, I am trying to answer your PM, but I get the error, "Some users couldn’t be added as they have disabled private message receipt." you may wish to check your forum account settings.
Best,
-Mike
765nkp
Post by 765nkp »
I have had the same problem sending BClemens a PM, for some time. I tried to get the moderators to help, they tried with no luck.
Tim
Harlock
Post by Harlock »
765nkp wrote:I have had the same problem sending BClemens a PM, for some time. I tried to get the moderators to help, they tried with no luck.
Tim
Under user control panel, board preferences tab, then edit global settings sub-tab, and make sure "Allow users to send you private messages" is set to 'yes'.
If messages still fail to appear, it's possible his inbox is full.
BClemens
Post by BClemens »
I checked, the settings were incorrect.... they should be correct now for PM's. Sorry about that, not sure what happened because I had been receiving PM's in the past.
BC
BClemens
Post by BClemens »
Has someone purchased this total set of 24 couplers??? Are these from Allen Models?
BC
BClemens wrote:Has someone purchased this total set of 24 couplers??? Are these from Allen Models?
BC
According to the original post:
"This is set of 24 Dave Skagan 2.5" scale bronze coupler castings"
