Steam dome seal
Steam dome seal
Hi all,
I finally finished rolling in all of the tubes and wanted to do an initial test on air at 20 psi. Low and behold the dome flange joint leaks. Upon further investigation, I determined that there's a "rock" between the flange and dome base and when rocked to one side shows a 0.010 gap. I'm guessing the flange distorted when welding. I tried using a 1/32 thick steam rated gasket however I couldn't get it to seal. I got a print on the steam dome bottom at the surface plate and it's perfectly flat. The flange/dome joint is now curing with permatex ultra copper and loctite 567 on all screws. Is there another method I should look at if this doesn't work?
-jlakes85
-jlakes85
Re: Steam dome seal
Try chucking the whole dome cap up in the lathe and taking a face cut across it to true it up. I always do that with the steam dome caps after welding. If you leave it just a bit rough when you machine it, it will help that gasket get a good bite as well.
Re: Steam dome seal
I checked the dome base on the surface plate and there was no rocking. I'm thinking the distortion is in the flange surface
Re: Steam dome seal
Suggest putting Dykem blue (or similar) on the base and dome, and rubbing the two together with some lapping compound. The high points will show as bare metal. Scrape or file them down and repeat until there are no high spots.
Dan Watson
Chattanooga, TN
Chattanooga, TN
Re: Steam dome seal
Fender,
Gotcha. That's my next move if the ultra copper doesn't hold up.
Re: Steam dome seal
Ten thou on a large surface will not be fun to remove.
If the boiler isn't mounted, you might consider fly cutting the flange surface. You'd be better served spending your time making the mill setup than struggling with a surface that won't be easy to flatten. Fly cutting will yield a very flat surface if addressed properly.
Re: Steam dome seal
Harold,
Sounds good..I was over at the HF website double checking the reviews on the 1000lb hydraulic table cart. I'm keeping my fingers crossed that the Ultra Copper gives me a pass on this one. Has anyone used that stuff for steam dome sealing before?
- makinsmoke
Re: Steam dome seal
Not a hijack but you mentioned a hydraulic cart.
I have one of their orange ones. Not sure of the rating.
Beware of their wheels. If you have a shop with a perfectly clean floor and will never get gravel or chips on it no problem. I had gravel tossed into the garage shop and rolling the cart with the hard plastic wheels on a few pieces of gravel
tears them up. I know, cleanliness and Godliness, but I live in the country, the shop doubles as a garage, and I have dogs.
Solid steel wheels would have been a better choice for me had I known.
Back to the topic. How do you get a fly cutter into a 1-1-2" scale boiler?
Tks,
Brian
Tks,
Brian
- makinsmoke
Re: Steam dome seal
One other cart issue. It has bled down from day one.
Re: Steam dome seal
Makinsmoke,
Thanks for the heads up on the cart. The surface with the issue is the top of the dome flange itself, so no problem with cutter access..I will have to squeeze around the exposed throttle and turret piping, bit shouldn't be an issue with a 1.000 dia insert cutter
Re: Steam dome seal
It's not easy to mount a boiler on the mill and get it perfectly square. Keeping it from moving is tough too. I've done it a couple of times. Once made two saddle blocks to go under the barrel. That made it level lengthwise. I used heavy chain and draw bolts on the T nuts to hold it down.
Good luck.
Good luck.
Fred V
Pensacola, Fl.
Pensacola, Fl.
Re: Steam dome seal
Another direction would be to cut the studding flange out then true it in the lathe again.
Re weld it back in place but this time be sure to tack it in place with lots more tack before the root pass.
John B
John B
