AIR COMPRESSOR IDENTIFCATION
Re: AIR COMPRESSOR IDENTIFCATION
No problem!
If you build either of these pumps, please give us a report with photos! I am interested in what the operational differences between these single cylinder pumps are compared to the two cylinder types.
David
David
Baum pump with a twist. Water port are pointing different. Yes I have prints but not for sale as they do not belong to me. I have built 15 of them and there is tricks to making them work. Call me maybe I can help. Steve Alley Allen models 775-782-3800 willing to help out.
- SZuiderveen
There is an erata that goes with that Modeltec article. I'm on the road, but I can get the issue when I return home
Thanks Steve Alley, I'll drop you an email or call early next week.
SZuideerveen, that would be awesome, any information would be super helpful.
~Anthony~
~Ex Pat Kiwi now living in Salt Lake City, Utah
- Greg_Lewis
Steve:SZuiderveen wrote:There is an erata that goes with that Modeltec article. I'm on the road, but I can get the issue when I return home
If you can find it and post it, that would be most helpful. Thanks.
Greg Lewis, Prop.
I have recently Resurrected the drawings and instructions for the Little Engines pump number one pump number to pump number 3 and pump number 4. They are now in book form and The Complete Book is $40 also available is the mood Ebron designed duplex water pump which was the a 15 - 100 I sell the drawings and 3-piece casting set for it
By chance Steve, did you find the erata??SZuiderveen wrote:There is an erata that goes with that Modeltec article. I'm on the road, but I can get the issue when I return home
Cheers
~Anthony~
Hello all,
I'd like some advice, Has anyone got any experience with this style air filter/one way check valves?? I'd like to take them apart for servicing, but don't see how the "triangle" piece comes out. The body's appear (no visible joins) to be be one piece.
I'd like any advice on the disassembly if anyone has any.
Thanks in advance
Thanks in advance
~Anthony~
Is this part of an air compressor?
yes , they are the air intakes on the compressor side of a steam pump/compressor.Builder01 wrote:Is this part of an air compressor?
In one of my first photos you can see them on the side of the unit.
~Anthony~
Has anybody seen anything like this before and can give me some advice on disassembly for cleaning/servicing ??
~Anthony~
Just soak it in some lacquer thinner to remove any oil or grease. If it is brass, copper, or bronze, soak it in citric acid. Don't take it apart.
David
David
