Re-manufactured 1-1/2” Scale Two Unit Searchlight Signal ****SOLD****
For the Buying/Selling/Trading of items of interest to those of us in the Live Steam Hobby.
Atkinson_Railroad
Post by Atkinson_Railroad »
Product Number: D271-2PS3
Two Unit Ground Signal w/Double Instrument Case.
Assembled in permissive signal arrangement with number plate and aluminum-silver paint scheme.
Nominal height 34 inches.
Searchlight heads employ earlier 3-coil operating units enabling a variety of installation and wiring possibilities.
Permanent magnet rotor and color disk rotate in phosphor bronze bearing toward any energized coil.
Input can be continuous or momentary pulse actuated. Unit holds aspect with or without power.
Units are retrofitted with 2700K warm white LED light source.
Constructed of outstanding weather resistant molded plastic and aluminum components with stainless steel
mechanical fasteners.
Prewired signal leads (AWG 22). Six leads per unit.
End user must configure how they will control the device.
Removable back panels on double instrument case provide accessibility and feature recessed neoprene gasket
to keep out weather. Bottom of base has two 1/2” –NPT threaded outlets not illustrated on attached
mounting base dimension drawing.
Non-operating door front details include door hinges, hasps, padlocks, large type ventilators, and all the rivet heads to count.
Non-mounted previously used wood display base is available for this signal.
Price: $840.00 Shipped (Contiguous U.S.A. Only)
Accept Pay Pal, Check or Money Order
You Tube Video for reference: https://youtu.be/UI-mqoX-SDk
Send inquiries to (atkinsonworks@gmail.com) with subject title: Two Unit Searchlight
Thank You!
John
pdul775712
Re: Re-manufactured 1-1/2” Scale Two Unit Searchlight Signal
Post by pdul775712 »
I'm interested in your searchlight I sent you a private message is it still available if so please fill in any details
Atkinson_Railroad
Drawing attached illustrates suggested method the Two Unit Searchlight w/302A mechanism(s) can be controlled using push-buttons and diodes to produce 7 different signal aspects.
Additional push-buttons and diodes connected to the circuit can provide more aspects.
A multi-point selector switch connected before the push-buttons can dictate the called for aspects.
The G, Y, and R letters to left of the push-button drawing symbols shown, denote the color aspects projected by the searchlight when the button on drawing is actuated.
(Also, the term “heads” used in this Market Place advertisement should have referred to “arms” ; )
oops! : )
John
Atkinson_Railroad
Searchlight has been SOLD.
