flatcar brake rigging
I have a flatcar which has brakes only on the front truck. It is activated by pulling up on a wooden dowel attached to the rigging with a braided stainless steel cable.
I would like to put brakes on both ends, and maybe use a better actuator, like a lever.
I know I will need to rig up some levers to equalize the braking.
Anyone have some diagrams or pictures of how to set this up?
Re: flatcar brake rigging
Steve:
Shoot me a direct e-mail and I will return some drawings...but it may well require that you make new trucks...
Great Bill; There's much interest in this as noted by the hits - well; Steve (and I and no doubt others) are too.... Give it all up Bill Shields!
Seriously, I looked around on the net to research this question and although there are diagrams and photos, there is nothing like experience - which you (Bill Shields) have. The data on the net on freight car braking systems is definitely not suitable for what a 1.5" / 2 1/2" (large scale) brake system entails - steam or air over manual.
Most interested too.... Thanks SteveM for the question - and thanks Bill Shields for an answer for Steve.... but may I get that data too?
Respectfully,
BC
Respectfully,
BC
all I need is e-mails. I cannot put pictures drawings on the bbs right now
- SZuiderveen
Look here for the Railway Hardware Company flatcar instructions:
http://ibls.org/files/2015/Railway_Hard ... oodcar.pdf
Absolutely Fantastic Steve! Thank you!!!SZuiderveen wrote:Look here for the Railway Hardware Company flatcar instructions:
That is great, but what do the truck linkages look like? Thanks, Kimball
Kimball,
Unless totaly and completely scale is desired, Tom Bee has a great design for air actuated and the hanger design is inside spread. Mr Shield's design will work that way too.
BC
BC
Email sent.Bill Shields wrote:Steve:
Thanks, Bill.
- SZuiderveen
The 1918 Master Car Builders sheet that goes well with the sheet in the Railway Hardware Co plans. Also a photo of how I installed MCB style brakes on an arch bar truck.
Regards,
Regards,
