A Bender for Arch Bars
Re: A Bender for Arch Bars
That is a nice design! Sure beats the way I did the arch bars for my shay!
Thanks for sharing the drawings!
- Greg_Lewis
A slight cut into the bar at the bend point with a hacksaw will insure that the bend happens at the exact spot you want, and will give a nice sharp bend. Such a cut is unlikely to compromise the strength of the bar considering the forces applied to the truck, but you can fill it in with silver solder, which is what I've done.
Greg Lewis, Prop.
I agree! The shop press bent the bars easily but some of mine got a little off so required some banging and prying to assemble. I’ll definitely give this idea a go when I start making rolling stock archbars.Brian Hilgert wrote:That is a nice design! Sure beats the way I did the arch bars for my shay!
-Tristan
Projects
Projects
You might think about adding a set screw on the die block. I have found that no matter how tight the fit between the two blocks the force of bending the arch bar can make it slide from its original position giving inconsistent bends.
Just a thought.
Jeff Smith
Just a thought.
Jeff Smith
Center the die block and bend two angles at the same time...jeffsmith wrote:You might think about adding a set screw on the die block. I have found that no matter how tight the fit between the two blocks the force of bending the arch bar can make it slide from its original position giving inconsistent bends.
Just a thought.
Jeff Smith
I discovered this too. As you say when trying to bend the 1/4" x 5/8" bars it tends to move no matter how tight the bolts.You might think about adding a set screw on the die block. I have found that no matter how tight the fit between the two blocks the force of bending the arch bar can make it slide from its original position giving inconsistent bends.
Just a thought
My thought is to cut a rabbit about .0625 deep for the die block to sit down into the plate giving it a stop to go against.
I will try it this weekend.
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
I am thinking along these lines
Charlie Pipes
Current Projects:
Current Projects:
Charlie,
Since you have drilled the arch bar blank material for the bolster pedistals, use the holes on dowel pins or bolts through the clamp blocks to assure the bends are the same distance from each hole when you turn the blank over to do the other end. Add a hole through the anchor blocks and slide a dowel pin or bolt through them with the blank between them. You may need to relocate the outer bolt holding the bend block in its seat slot.
Down and dirty 'out of perspective' sketch:
This is an interesting approach.
My drawings are a little misrepresenting as I am planning on using the fixtures to drill the holes after bending.
You method would definitely have merit.
I did this tonight before running off to church. it is a stop guide attempt. I also swung by the steel yard to get a piece heavy wall tubing to make a cheater bar for the bending arm.
Out of curiosity. is your drawing in Solidworks?
Charlie Pipes
Current Projects:
Current Projects:
Keycreator - it doesn't like being converted to a jpg. Stops are a good thing.
Charlie - another method: http://www.nelsonslocomotive.com/Small% ... ckBars.htm
