Belpaire Boiler for a PRR G-5
Marty_Knox
Post by Marty_Knox »
We are building a Belpaire Boiler for a 1.5" scale PRR G-5. Here are some pictures.
Marty_Knox
Re: Belpaire Boiler for a PRR G-5
Here are the parts before we started assembling them,
Marty_Knox
One unusual feature of Pennsy boilers is the injectors are on the backhead, with internal feed lines to carry the water to the front of he boiler. This shows the brackets to support those internal feed lines.
JohnHudak
Post by JohnHudak »
Looking great Marty...!
Marty_Knox
The flat side surfaces above the crown sheet need stays. They go above the crown sheet across to the other side. The challenge is making sure the stays going in 3 different directions don't intersect.
Marty_Knox
Here are some pictures of the inner firebox. The sides and top were formed from one piece of 5/16" PVQ plate, with the rear tube sheet and door sheet welded in.
dnevil
Post by dnevil »
Simply amazing work Marty!
Daris Nevil
IBLS Secretary
North American Region
http://www.ibls.org
Oktrainboys
Post by Oktrainboys »
Nice work Marty, I have completed chassis for an LMS Black 5 (highlander, 1.5" scale, 7.5" gauge) that needs a bel pair boiler. Martin Evans design and I have the drawings. Are you able to give me an approx. quote for this boiler? Non superheated. Feel free to PM me if you would like. Thank you. Mike
Marty:
Inspiring to see your work.
I like the looks of the Belpaire boilers, living in former Great Northern RR territory. Added complexity to construct, though.
Thanks for sharing.
jcbrock
Post by jcbrock »
That looks difficult Marty, but probably not any more than anything else you guys do. Since the injectors are on the backhead for PRR locos, what's the check valve arrangement? I'm assuming there would be some, also somewhere around the backhead?
John Brock
JohnHudak
Post by JohnHudak »
jcbrock wrote:That looks difficult Marty, but probably not any more than anything else you guys do. Since the injectors are on the backhead for PRR locos, what's the check valve arrangement? I'm assuming there would be some, also somewhere around the backhead?
In this case, the injectors are along the outside of the firebox and toward the rear.. The check valves are on the backhead..
John
Asteamhead
Post by Asteamhead »
Marty,
Amazing work!
Thank you for posting the steps of your building process, which is straight forward as with other boilers you built.
Just professional steel work and welding! It is prone to work safely for lots of years to come.
Asteamhed
