steam engine need help!
Re: steam engine need help!
As to your boiler, I don't think it would need to be as large as you are thinking. I built 2 locos that had 3" by 4" cylinders and the boiler was a piece of 10" pipe and a grate of 100 square inches. This would produce more steam than the engine needed. You are talking about less cyl area so the same boiler would be more than enough. I would consider a vertical boiler for your application and use a 10" pipe.
Most state boiler codes exempt hobby boilers that have less than a certain amount of heating surface and water volume so check your state code. This would make life much simpler for you. Also look at firing with coal. Wood burns so fast and puts out much less BTU's.
Fred V
Pensacola, Fl.
Pensacola, Fl.
I am not against using steel for cylinders, but it must be cared for. Cast iron or steel will both rust if the bores are not oiled after a run.
If you are using steel and fabricating cylinders, it's got to be made a certain way. I would complete all the welding, then heat cycle the fabrications in the oven several times to your estimated operating temperature. *Then* do your final boring of the cylinders, facing of the ends, and bolt everything together.
I think one could even use stainless pipe, although expensive in seamless, along with a brass piston it would be pretty bulletproof as far as corrosion. I think that with the low rpm and clearances common in steam, that any heat deformation beyond this is going to minor and not of consequence.
Stainless for a cylinder is not the best way to go. Corrosion may be less, but I would be more concerned about operation and wear of stainless on anything.
What Bill said. Stainless, especially the 300 series, makes a miserable bearing, a feature that walls must have. Stainless is well known for its ability to gall.
Might have acceptable results using 416, heat treated, however, assuming one has deep pockets.
^ Agreed, however this would depend completely upon what ring material was used.
Honda, for example, uses a fairly soft ring material and in most engines the liners are steel, cast in aluminum. I've taken apart engines with 150K-225K miles on them to find the factory cross-hatching still there, and the rings in various states of wear from decent to nearly gone.
If the piston and rings are made properly with the design of these steam cylinders(the piston has no skirt), the piston should never touch the cylinder walls.
I'll have to take a teaser pic of the stainless pipe scrap bin at work for you guys:)
ring material matters not...anything sliding on stainless steel is a bad combination.
A lot of air cylinders are built with stainless bodies and PTFE (Teflon) rings, and they last for decades.
I'd agree that anything metal sliding on stainless would be bad.
totally agree, however air cylinders are an entirely different situation from a steam application.
Bill reflects my thoughts nicely.
I like stainless---like it a lot, but it is best used for the appropriate application.
Something to ponder.
17-4 PH rivals 4140 in many ways----with the added benefit of corrosion resistance. Were I tempted, I'd likely try it for steam, along with 416.
Nice box of stainless tubing. Tell your boss I have plenty of room in my shop to store it if he'd like to donate to the cause!
Again, a whole lot to consider. This is why I would ask of those who have the knowledge and experience. In the hope to minimize the chances of mistakes. While having a reasonable background in industry, when it comes to steam. I was, born yesterday. With some study and the advice given I hope I am beginning to grasp some of the concepts as of materials needed.
It sounds like cast iron will be the logical choice. If I go with a casting. Should I be looking at ductile or gray iron? I had considered Teflon rings but ring design / material along with the piston. Will be a major component that will be one of the later parts fabricated. I will be visiting this subject in great detail in the spring. Thoughts now are for a cast turned bronze piston but once again this will be determined later with advice from those more knowledge on the subject than myself.
Joe
Joe
Harold, research shows that many manufacturers "formula's" of PTFE have a temperature rating to 400*+. I've made several pieces of equipment for production environments that used air cylinders to clamp something several times a minute, and these fixtures are still working well after 10 years and who knows how many parts. Also, I found a manufacturer that makes "X-seals" which have a 435* rating in reciprocal use, applicable for steam, and in a whole bunch of various sizes. They look like they'd work really well.
Sadly, 99% of us have little use for the pipe remnants and about twice a year it just gets dumped in the recycle dumpster which we only get $20-$40 a ton for. We also get stuff back from the jobsites that just goes in there as well, it kills me to see, but it's not worth it to have somebody sell it all in a surplus situation. Chain, bolts, nuts, washers, anchors, threaded studs and rod, cable, pipe fittings, metal rems, buckets, welding cloth, you name it. I dumpster dive on occasion lol. I'm sure I could get you some with a small donation to the office donut fund if you are up this way.
