A Long Term Project
Fred_V
Re: A Long Term Project
Post by Fred_V »
Steve Goodbody wrote: Mon Jan 08, 2018 6:23 pm Hi Fred - I can't remember if your loco is the Milner or Don Young 4 inch scale design? I've heard that the valve gear on one of these designs can benefit from modification but can't recall which one. The valve events on the Elidir design seem good while bench-running on air, time will tell how it performs on the track however.
The notched lever is the steam brake valve - it's a modified version of the Martin Evans progressive application design for Highlander. The original design uses a rotary handle, I've modified it to a more prototypical-looking pull to apply, push to release version.
Best regards
Ah, I didn't realize you built the Elidir engine. Mine is the Milner design. It is not as close to prototype as the 3" designs. The firebox part of the boiler doesn't stick up to provide steam space but it fires well and has not primed.
Fred V
Fred V
Pensacola, Fl.
Steve Goodbody
Post by Steve Goodbody »
Hi all,
Well, all of the major bits and pieces are now complete and the time has come to start pulling things apart for painting. Here are a bunch of pictures taken this weekend in readiness......
Oak toolbox:
Vacuum hose and coupling:
More to follow,
Steve Goodbody
Rear Primary Coupling (Removable):
Driver's side Injector water valve lever. Cylinder drain cock and steam chest drain cock levers below:
Fireman's side injector water valve lever and ashpan damper below.
More to follow....
Last edited by Steve Goodbody on Mon Dec 09, 2019 6:39 pm, edited 2 times in total.
Fred_V
Post by Fred_V »
Very nicely done Steve. The spring buffers were never used on the working Hunslets nor did they have cabs. That would make your design a Preservation engine as all that was added for their present working.
Is this a 4" scale engine?
Fred
Fred V
Pensacola, Fl.
Steve Goodbody
Final version of the duplex vacuum brake gauge. Steam brake gauge below.
Vacuum ejector:
Last edited by Steve Goodbody on Mon Dec 09, 2019 6:40 pm, edited 1 time in total.
Steve Goodbody
Steam chest drain cock arrangement:
Steve Goodbody
Water filler and brass mesh strainer (inner water tank is copper):
Now to start the final tear-down!
Best regards
Fred_V
Post by Fred_V »
Great detail Steve. Did you add a superheater? I here these are wet engines to run with all that cylinder and steamchest iron.
Fred V
Pensacola, Fl.
Post by Glenn Brooks »
Steve, Work of Art! Thanks very much for posting your photos.
Where did you find those remarkable clover leaf valve handles and that nifty Vacuum gauge?
Sandiapaul
Post by Sandiapaul »
Very nice work and a great looking little engine!
Wow! I love seeing fine workmanship and detail. Very nicely done!
I really like that nice little oak box.
Steve Goodbody
Hi all, and many thanks.
In quick response to the questions:
Fred:
The loco is based around the 3" scale Elidir design. Although not in original condition, like most of them now, I've always been fond of Holy War on the Bala Lake Railway and generally like the look of buffers and a full cab. Since I'm not modelling an exact prototype I've added and modified a bunch of things to suit my personal taste and preferences.
I have two stainless steel superheaters but have not extended them into the firebox. Hence they're more likely steam driers than superheaters. You can make them out in some of the earlier spark arrestor / smokebox pictures.
Glenn:
The duplex vacuum gauge is home-built based around the guts of two small commercial gauges arranged back-to-back. The investment cast handwheels are available from Macc Models in the UK, see: https://maccmodels.co.uk/product-catego ... and-wheel/
Best regards
