Bill, my buddy and I have a copy of your 1-1/2" scale Van Brocklin duplex pump plans, can they simply be re-dimensioned to 1" scale,or would something in the design have to change for the smaller components?
John
Question for Bill Shields
Re: Question for Bill Shields
THEORITICALLY yes...however...
You cannot just shrink everything to 1" scale since some of the components do not 'scale' correctly and some of the hole clearances for passageways become really tight between 1 and 1-1/2"....which makes the valve timing a little bit off.
In reality, if you were to use the 3/4" scale pump, it will look just fine for a 1" loco...which is what most people did (do).
If you need the 3/4" PUMP drawings., send me an e-mail.
bshields at mehrs dot com.
Will do, thanks Bill.
John
John
