Slide duplicator / digitizer
We have maybe 6 cubic feet of slides my dad took.
We don't want to go thru them and pick and choose which to digitize, nor do we want to pay a service (LegacyBox wants $1,000 to do 40 boxes of 25 slides).
I'm thinking that the best thing to do is to BUY the slide digitizer, use it and then re-sell it, as our cost will be the difference between the buy and sell.
One with an automatic feed would be a plus (or at least one that lets you stack them and manually feed them from the stack rather than having to load them one at a time by hand)
Anyone have any experience with one of these?
Re: Slide duplicator / digitizer
I have a similar problem. The older Nikon would be ideal but discontinued and are not so compatible with modern computers. I am still looking for a solution but not very hard. e-bay is probably best place for a used / rebuilt one. There are a couple people who make a business of this.
I've got no experience with automated batch slide scanners, I've only done it with manual ones but
with the the amounts you have it would be a full time job + to scan them all even with an automated
one. Scanning resolution might be a problem with older scanners the sensors would be lower in resolution compared to
the cheapest modern day point and shoot digital camera or even a cel phone. That coupled with a computer that
would run the drivers for the scanner.
You got me thinking about aerial imaging ( not the taking pictures of land from above ), not a lot of info online since it
seemed to have gone the way of the dinosaur, but back in the day I worked at a animation company that had aerial image
printers used for film effects work, it was a method of projecting an image focused at a determined distance in air so that
multiple images with masks could be combined and re shot.
Basically the printers ( they were called optical benches, not to be confused with lens optical benches ) were a motion picture camera
and projectors mounted on a precision lathe bed. To keep it short, I was wondering if it was possible to just use a slide projector
to aerial image the projected slide directly onto a DSLR sensor.
And I stumbled upon this - https://www.youtube.com/watch?v=0Vfnc0iJmks
that's a commercial unit, there are also other videos's of DIY batch slide scanners on Youtube too.
Something to consider if you're game to tinker a bit.
Here's a DIY version:
https://www.youtube.com/watch?v=XPCpwcn2Q6w
Certainly do-able.
Interesting that SlideSnap will rent them to you, but only in Scandinavia.
Certainly do-able.
Strange that it's only rentable in Scandinavia, this place rents in the US, but do research about them first
it's just a site I came across yesterday -
https://services.ezphotoscan.com/rent-p ... oto-slide/
I'm sure that SlideSnap got the idea from the photography DIY'ers, if you have a slide projector
and I would would assume you would if you have 6 cubic feet of slides, it'll be a cheap experiment to
try, if the results are good enough then you're on your way, if not it's a good excuse to buy your
self a new DSLR or if you have one a new lens !
Tell your wife what ?
pacific image has a unit that does batches of 50 slides.
$1000....
what is your time worth?
$1000....
Exactly the point I'm trying to make to my family.Bill Shields wrote: ↑Wed May 02, 2018 12:02 pm pacific image has a unit that does batches of 50 slides.
$1000....
We don't have the time to look thru 9,000 slides to see which to copy and which not to copy.
Disk space is so cheap, it's a non-issue - you can buy 2tb in a blister pack at the Best Buy checkout for under $100.
And the cost for the duplicator isn't $1,000 - it's $1,000 less how much you can sell it for. Even if you took a bath on it, that would make it $500.
