Building a Veranda
Re: Building a Veranda
Post by NP317 » Wed Jul 04, 2018 9:32 am
"Somehow I need to build a seat into it and still make it look good."
Make a round top section of the tank that slides aft to expose the seat.
It will need to lift just enough to accommodate the radius mismatch, when the seat is exposed.
Harlock
Post by Harlock » Wed Jul 04, 2018 5:17 pm
There's a turbine engine and something like one of those tank cars on display at Ogden Union Station in Utah. Not sure if Veranda version, can't see on that side in my photos. It was hard to get a photo as the rows of engines are very close to each other.
In any case, if it's on the path to being the right thing, it could be quite a useful direct measurement reference.
Contributing Editor, Live Steam Magazine
Webmaster, Allen Models of Nevada
JohnHudak
Post by JohnHudak » Wed Jul 04, 2018 10:07 pm
About ten or so years ago, I seriously considered building one in 3/4" scale.. I was going to use one of the then "new" turbine engines for RC jets.. One of the manufacturers had a helicopter version with a reducing gearbox.. The engine was 5" diameter, and if I remember correctly the locomotive was 7.5" wide, so it would have fit nicely..
The engine was going to turn a generator, and make electricity to power motors on the axles.. For a while, I was corresponding with a gentleman in the UK who did build one that way, but I think it might have been 5" gauge..?
Anyway, good luck with your project..
Broken Knuckle
Post by Broken Knuckle » Wed Jul 04, 2018 11:24 pm
The one in Utah is a third generation but the tanker car is the same as the second generation GTEL. I have a trip planned there in October for photos and measurements. Was going to do an A-B third gen but that would be just to long and I don't like the trucks under it. Thank you for the photos.
I'm retired now. If it's not fun, I'm not gonna do it. :mrgreen:
Broken Knuckle
Post by Broken Knuckle » Wed Jul 04, 2018 11:34 pm
Did you have a set of drawings to build off of? I have a RC jet turbine engine and thought about using it. Because you can't scale down heat I've decided to run a gas engine with a high speed blower for sound affects. The second gen had a diesel engine, to move it in the yard so it's not so out of line to not run the turbine at low speeds.
JohnHudak
Post by JohnHudak » Thu Jul 05, 2018 3:32 pm
No, I didn't have any prints, sorry.. I remember seeing something in Model Railroader though if that helps..?
BTW, here's a video of the man in the UK...
https://www.youtube.com/watch?v=nXSuSgGbrHc
John
JohnHudak
Post by JohnHudak » Thu Jul 05, 2018 3:38 pm
steamingdon
Post by steamingdon » Fri Jul 06, 2018 7:38 am
Ah! but will it reverse ?
steamer
JohnHudak
Post by JohnHudak » Fri Jul 06, 2018 10:12 am
In one of the videos he reversed it
gwilson0704
Post by gwilson0704 » Tue Jul 10, 2018 2:30 am
There is book called Turbines Westward that has a number of photos and some drawings with spec.It's a great book about the history of the UP turbine program. You may want to find that book, I have read mine a number of times looking for info on the turbine locomotives. I am interested in the steam turbine ones. Good luck
johnpenn74
Post by johnpenn74 » Wed Jul 11, 2018 10:26 am
There were two different tender. The totally round one being nick named the "beer Can" I think.
JP
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
Broken Knuckle
Post by Broken Knuckle » Thu Jul 12, 2018 8:48 pm
JP
You are right. The Veranda had the round sided fuel tender that was nicknamed the "Beer Can" and the third generation "Big Blow" had a square fuel tender.
