Glue for Plastic in Gasoline Tank
John Hasler
Re: Glue for Plastic in Gasoline Tank
Post by John Hasler »
BadDog wrote: Fri Aug 03, 2018 4:02 pm I forget the name, but McMaster sells those small fuel lines (and a range of sizes) in a material that is (and stays) soft and flexible. I bought something like 2' and replumbed all mine years ago due to the OEM just disintegrating. Haven't had any trouble at all since. From memory, it's a yellowish cream tubing. I just did some google research and found a lot of solid suggestions about the material, but I don't think it was neoprene.
Neoprene is always black, as far as I know. https://www.usplastic.com/catalog/defau ... tcatid=856
GlennW
Post by GlennW »
Tygon
SteveHGraham
Post by SteveHGraham »
I have used tygon for diesel without problems. I'll bet Ebay has tons of it.
John Hasler
Tygon is a trademark: the owner puts it on all sorts of tubing. The specific products intended for fuel lines are https://www.usplastic.com/catalog/item. ... &catid=864 or https://www.usplastic.com/catalog/item. ... &catid=864. Of course other companies sell equivalent products.
BadDog
Post by BadDog »
That looks exactly like what I used. I don't remember where I first heard about it (maybe here), but the lines I replaced with it are still going strong long after the OEM would have been crumbled.
liveaboard
Post by liveaboard »
It's crazy how manufacturers make small economies like scrimping on fuel lines.
I had a pressurized gasoline line blow over the engine in a BMW I had; it wasn't a very old car. Gasoline all over the hot engine bay, nuts.
The other day the rubber of the harmonic balancer / pulley in my present car failed, the pulley spun but kept turning so it was hard to tell. The AC stopped working, then the engine rapidly overheated nearly to destruction in just minutes.
I already blew one engine in this car due to the same fault. A good solid engine lost to one little weak point.
[rant, rave....]
BadDog
Post by BadDog »
But the increased margin got a useless MBA his bonus to buy a third vacation home with some left over for a new supercar to add to his collection. So it's all good as long as customer warranty complaints dont get filed before next quarter...
Gluing plastic is a challenge, especially in the presence of the described (and expected) chemicals.
The thought of using a soldering iron to fuse them is good...have you ever seen a HEAT GUN used to 'weld plastic'?
A solvent that will dissolve the pieces so that they can be 'stuck' to each other is a good direction to go as a last resort...think PVC pipe 'glue' which in reality is not a glue at all but a solvent.
Tygon is great stuff if it solves the problem...but beware trying to 'glue' it.
