Perfect!!!Rick wrote: ↑Thu Nov 29, 2018 12:45 pm Well, breaking a tap is like sailing a small dagger board sail boat. There are those that have capsized and there are those that are going to capsize.
It will eventually happen if you do it enough. Sometimes for reasons out of your control. Then sometimes we are just stupid
feeling stupid
- neanderman
Re: feeling stupid
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
- neanderman
Re: feeling stupid
I appreciate your faith, Spro... Whether I qualify is a whole other thing!!!
Ed
Atlas 618
Atlas 618
Re: feeling stupid
Brilliance is often not seen while stupidity shines. It shines because it is out of order.
- liveaboard
Re: feeling stupid
Come on, you can do better than that!
I knew a guy we used to call "Captain capsize" because he flipped his hobycat every time he took it out.
I towed him away from the rocks in heavy surf with a sailboard once. That was hard. I had no buoyancy.
Anyway, my point is that I'm not a tap breaking virgin. Not as bad as Captain capsize, but repeating the same mistake again is... you know.
Today I went to my metal shop and made something clever; that could be the antidote to feeling stupid. I think it will take 2 or 3 clever things to get my ego back to it's overheated baseline level.
Re: feeling stupid
Three ,eh ? At that rate it's going to be 2019 for me after that welding I just did.
Re: feeling stupid
Well, if it makes you feel any better, I haven't broken this tap yet.
--earlgo
Maybe next time it gets used. --earlgo
- liveaboard
Re: feeling stupid
I have an extra big tap handle just for jobs like that.
Re: feeling stupid
the biggest challenge regarding using a tap is knowing when to throw it away (when it is dull). Everyone wants to get 'the last hole'.
the second biggest is to never use one unless you have it held by a center so that you cannot snap it off.
beyond that...piece of cake (giggle....)
I remember when Jim did the 2-56 holes in the cast iron of his cylinders. he had 48 holes and 48 taps (all carbon steel in those days)….one hole, one tap...
he got through it OK and had a drawer full of 'once used' 2-56 taps which I inherited from him 50 years later...and am still using....and throwing away as soon as they begin to feel 'sticky'.
- warmstrong1955
Re: feeling stupid
Next time you thread something with it, use a 3/4" drive impact wrench.
That'll get her done!
Re: feeling stupid
By "get her done" do you mean put threads in the hole or break the tap?
--earlgo
--earlgo
- tornitore45
Re: feeling stupid
I would not mess with a guy that can break a 1.5" Tap by hand.
Mauro Gaetano
in Austin TX
in Austin TX
Re: feeling stupid
Well I was thinking about this thread the other day when I was taping a #8-32 set screw into a small threaded rod holder- nut- fitting - thingy that holds the pullrod in the tailgate of my pickup. (The plastic thing disintegrated).now my part is only 7/8” long and 1/2” diameter at its widest. Drilled and threaded on the thick end to hold the pull rod that opens the latch on the tailgate. Took two days to make.
So Iam threading the set screw into a blind hole to hold the rod to the latch handle in the tailgate, Thinking how do you break taps anyway? I hardly ever break taps. Well, a moment latter “tick” and my $15, All -American, shiny new tap was rendered in two jagged, ugly pieces. Leaving the best part of the broken off tap fully embedded in my part - where it resides to this very day. Nothing to it, as my old machinist buddy would say.
At least I knew how to gin up a duplicate part, without to much trouble. Without the set screw.
