Trike build, almost finished.
Re: Trike build, almost finished.
That doesn't matter now. Your unique trike is looking better all the time.
I did a little work on the new chassis over the last few days, added mounts for a shocky, the mounts give me five settings and around 100mm of travel. The shocky weighs 400 grams but the fork stays that aren't required with the shockies save 400 grams so the chassis should be around 100 grams heavier, I can live with that.
I ride a Trike, simply to remove the threat of wiping out and not being able to work. Bought a used Terra Trike. Uses an 8 speed hub, direct drive from the front pedals.
Word of caution, you MUST use clicker pedals and shoes. Should your feet fall off the pedals(they will!!!) you will run over your own legs and get badly injured. Think my right leg has fully recovered, it used to swell up badly.
I've been riding tadpoles for around 20 years, still got my feet...
Well you just jinxed yourself, get pedals that lock your feet.
No need, 20 years experience says - nope.
A little more work done on the new chassis: Completed the swinging arm and suspension as well as the squab and shaped the backrest.
Nice fabrication work!
I like the whole project. We can see where things were tacked then more scrutiny and finally welded. I wouldn't know a squab from a shockie but by golly, that support is adjustable. Neat shop too.
Made a bit of a boo boo with the suspension: didn't allow for my weight so had to make new mounts and order a shorter shocky. While waiting I spotted some cable guides in place, attached mounts for a rack, shaped a luggage rack, tacked the front deraileur mount on and attached the chain idlers. The new suspension now has nine settings in lieu of five, bit of a waste but it does look good. I'll attach a couple of chain idlers up front tomorrow and then it's just a matter of waiting for the shocky to arrive.
Nice!
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
