magnetic parallels / transfer blocks
SteveM
Post by SteveM »
I see magnetic parallels that are alternating stacked plates of brass and steel, and I see some that are blocks of brass with steel pins in them.
Any difference between the two types?
Wolfgang
Re: magnetic parallels / transfer blocks
Post by Wolfgang »
SteveM wrote: Thu Jan 24, 2019 5:02 pm I see magnetic parallels that are alternating stacked plates of brass and steel, and I see some that are blocks of brass with steel pins in them.
To use the parallel plate blocks the plates must be aligned parallel with the poles on the chuck. Thus you can use 4 surfaces of the block for contact with the chuck and work piece.
The block with pins may be used in any direction as long as the pinned surface is in contact with the chuck and the work. This type is also much easier to make yourself.
I suspect that the parallel plates block has the higher holding strength with a given chuck and work piece when properly employed. w
