Project: N&W class J on 5"gauge
Re: Project: N&W class J on 5"gauge
Great job!
- JBodenmann
Hello My Friends
I have been enjoying the progress on the J. Your workmanship is superb, there is no better. The trailing truck fabrication was quite a puzzle. Cut, bend, weld on the dotted line, beautiful!
Jack
Jack
- Steamchris
Hey Jack,
thank you for the warm recognition.
Still a lot work to do on the truck, suspension, axle compensation and so on.
We carry on.
All the very best
Chris
We carry on.
All the very best
Chris
The light at the end of the tunnel could be a train
Health and Safety Notice
due to the current economic circumstances , the light at the end of the tunnel
has been switched off !
Hello steamchris,
You and your father as team did a very fine job, indeed!
Just one look to that type of trailer, when it will be finished after some more work. We are happy, both classes A and J hadn't their trailers been equiped with a brake
Carry on!
Asteamhead
Carry on!
Asteamhead
Jewelry.
- Steamchris
Hi Guys,
a small Update on my J trailing truck.
The axleboxes are still under construction as you see.
Axelboxes made of bronze, also the timken covers they are casted. The axles will be mounted with 2 bearings on each side.
The suspenions with equilizing levers is also ready, pictures later on.
All the best
Chris
All the best
Chris
Such beautiful work!
- Steamchris
Hello,
thank you RN.
some pictures of the Axelboxes and equalizer....
All the best
thank you RN.
All the best
- Steamchris
Hi Guys,
some more pictures about the new parts on our J.
The smokebox and stalk are under construction .
The running gear is almost ready, suspension works fine and also the axle compensation from axel 1 to the last one of the trailing truck.
Best regards
Chris
Best regards
Chris
Gorgeous work, as usual.
Thanks for sharing.
RN
Thanks for sharing.
RN
- Steamchris
Hi folks, after finally getting a CAD program I was able to make the J characteristic nose. I did not want to do the work of a sheet metal construction, so I opted for a CNC construction from scratch. To be able to soak the raw material on the mill, I had to prick a groove. Then it went to the processing of the back, here I had to make room for the smoke chamber door and an approach to the smoke chamber. Then I could stretch the part on the lathe and produce the sophisticated contour. The nose immediately adapted to the smoke chamber. The rear section is the support for the boiler cladding made of 1mm brass sheet metal.
Some Pictures....
Kind Regards
Chris
Some Pictures....
Kind Regards
Chris
- Steamchris
Hi Guys,
some time ago after my last post, now it´s time to show Progress on our J 611.
The Cab outside structure is almost ready , so we have outside Points to work with. The Streamline cover is still under process, we did it all from brass sheet metal also the cab,
the Pilot is made of SS steel.
more in part2
more in part2
