GE 44 tonner
duckman903
GE 44 tonner
Post by duckman903 »
I've looked and found nothing, so if I use an HO engine which is 1/87 and I want to go up to 2 1/2" scale how much do I multiply the 1/87 ratio to get 2 1/2" scale
pete
Re: GE 44 tonner
Post by pete »
I know almost zero about locomotive building, so bearing that in mind since there track gauge is .650" apart for HO scale then to scale up to 2 1/2" you'd divide whatever gauge that uses by the .650". That should give you the multiplication factor. If it is exactly 2 1/2" then you'd multiply all the dimensions by 3.846
ALCOSTEAM
Re: GE 44 tonner
Post by ALCOSTEAM »
In HO one foot equals 87 feet or 1044 inches. In 2 1/2" scale one foot equals 2.5 inches.
If we take a 120" in HO scale that comes out to 1.379", the same 120" in 2.5" scale comes out to 25". That looks like from HO to 2.5" scale needs a multiplier of 18.129.
Rich_Carlstedt
Re: GE 44 tonner
Post by Rich_Carlstedt »
well, If HO is 1/8" to the foot and you want 2-1/2" to the foot , the 2-1/2" has 20 , one eights in it so the ratio is 20 to 1
Rich
ALCOSTEAM
Re: GE 44 tonner
Post by ALCOSTEAM »
If HO was 1/96 scale then 1/8" to the foot would work, but HO is 1/87 scale or 1 ft equals .13793 of an inch. 2.5 inches divided by .13793 equals a multiplier of 18.125136
4gsr
Re: GE 44 tonner
Post by 4gsr »
Would that be like laying 96 GE44 HO engines put end to end and be the length of a real one? :shock:
Ken
ALCOSTEAM
Re: GE 44 tonner
Post by ALCOSTEAM »
4gsr wrote: Mon Feb 11, 2019 6:20 pm Would that be like laying 96 GE44 HO engines put end to end and be the length of a real one? :shock:
nope
but if you put 87 end to end you would get real close to the prototype length
Rich_Carlstedt
Re: GE 44 tonner
ALCOSTEAM wrote: Mon Feb 11, 2019 12:15 am If HO was 1/96 scale then 1/8" to the foot would work, but HO is 1/87 scale or 1 ft equals .13793 of an inch. 2.5 inches divided by .13793 equals a multiplier of 18.125136
Thank You Alco !
I was always under the impression that it was called "HO" because it was HALF of "O" gauge-therefore HO.
Several train guys told me that years ago.
What is O-27 then ? and is O gauge 1/4" to the foot ?
Rich
rudd
Re: GE 44 tonner
Post by rudd »
Easier if you start with 1/4" - just move the decimal over one place. :)
duckman903
Re: GE 44 tonner
A friend had the April 1973 Model Railroader which has as the center fold a GE 44 tonner which is a measured drawing , so if I decide to go 2" scale do I just multiply the feet times 2 example 29' X 2 = 58" . my brain is just not being friendly lately.
toddalin
Re: GE 44 tonner
Post by toddalin »
I think that some people are confusing "scale" with "gauge." This is partially because the way in which the question was worded. Perhaps the OP can clarify which he has in mind.
rudd
Re: GE 44 tonner
Post by rudd »
the 2" scale example you give works.
If you want to go 2 1/2", just multiply feet x 12 x 2.5/12
29 feet is 348". 348 x 2.5/12 = 72.5".
With this method, if you had say 29'-6", you'd just add the 6" to the 348" to get 354" and you'd get 73-3/4"
