Rubber forming, aka Guerin process
whateg0
Re: Rubber forming, aka Guerin process
Post by whateg0 »
Looks good. That is one area where rigid forms excel, as they effectively planish out the tucks that are formed. Might not matter in this case, but I have at times had to do forming in steps, where the first step starts the part into the desired shape, then another form gets it closer, etc. More useful in deep drawing of parts, though.
Russ Hanscom
Post by Russ Hanscom »
I am going to need a number of assorted sizes and not too many of any one shape, so too many rigid forms is not enticing. The wood males are easy to make, not the females.
GlennW
Post by GlennW »
You should be able to use a small rawhide mallet and work the wrinkles out bu holding the part over the form and tapping on them.
Then maybe another squeeze in the press to finalize them.
Using a soft hammer such as rawhide on the metal part against the wood former will shrink the wrinkles, using a steel hammer against a similar hard surface such as a steel dolly will stretch the metal. (basic version)
Russ Hanscom
I have a nylon hammer, shot bag, dollies, and a few other goodies which I am using to clean them up. I just want to minimize the amount of finish work. The learning curve is improving.
Thanks for the comments.
