Wavy washers
toolroom
Wavy washers
Post by toolroom »
I hope this question is in the correct forum, as I have an application to utilize a wavy washer. The posed question is: How does someone determine the tensile strength /compression value of a wavy washer. My 19th Edition machinery's Handbook says nothing about the wavy washers. Does anyone in the forums know how to calculate the compression value of wavy washers? Internet doesn't help much, unless I am searching in the wrong place.
Thanks in advance for any information.
Magicniner
Re: Wavy washers
Post by Magicniner »
Ask a Manufacturer.
GlennW
Re: Wavy washers
Post by GlennW »
pete
Re: Wavy washers
Post by pete »
You could also try a search for Belleville washers as well. I believe that's the more common industrial name.
spro
Re: Wavy washers
Post by spro »
All we had to do was look a Glenn's links. A " wavy washer" is a set above regular shimming. If it is the right category and heat responsive, it can do what flat shims can't.
toolroom
Re: Wavy washers
Post by toolroom »
Wow, Thanks for all the information. I printed the page out for future references. I appreciate the help. Thanks again!
John Hasler
Re: Wavy washers
Post by John Hasler »
pete wrote: Sun May 19, 2019 11:20 pm You could also try a search for Belleville washers as well. I believe that's the more common industrial name.
No, wave washers are different. Belleville washers are sort of dome-shaped and flatten out under pressure. They typically have quite a high spring constant. Wave washers are "wavy": alternating high and low areas. They have lower spring constants.
Belleville washers: https://en.wikipedia.org/wiki/Belleville_washer
Wave washers: https://en.wikipedia.org/wiki/Washer_(h ... ng_washers
pete
Re: Wavy washers
Post by pete »
Thanks for the clarification John. As usual there's always more to learn.
