Drill shank hardness
- tornitore45
I was watching a guy on Utube making late tools from the shank of HSS broken drill bits.
I pointed out the the shank is not hardened.
He responded that in his case it is because he uses HS Conbalt.
That makes no sense since an alloy element added to improve the business end of a drill has no bearing on the necessity of having a softer shank to assure a good grip.
Is Co HSS drill shank hardened? Or he thinks that just because is Co is much harder.
Mauro Gaetano
in Austin TX
in Austin TX
- SteveHGraham
Re: Drill shank hardness
I have spun them, and it left marks, and I have filed the burrs off, so I think they are soft.
- tornitore45
Well, I saw it on the internet so it must be true. Yea.
Mauro Gaetano
in Austin TX
in Austin TX
I've never seen an HSS drill bit with a hard shank, cobalt included. If making something else, like a cutting tool, you can fix that with a torch and bucket of water.
Conrad
Yes, I saw that both Shakespeare and Abraham Lincoln said so.tornitore45 wrote: ↑Mon May 20, 2019 10:26 am Well, I saw it on the internet so it must be true. Yea.
Yes, they are not sharpened.
If you spin a burr on one and it won't go into the index, you can chuck it in the lathe and turn the burr off, rather than trying to file or stone it.
- tornitore45
Not HSS. Hardening HSS is a not a process available at the typical Home Shop Guy.you can fix that with a torch and bucket of water.
I make cutting tool from broken HSS bit but the only useful part is the web which basically limit the design to small grooving tool.
Mauro Gaetano
in Austin TX
in Austin TX
- Frank Ford
Unlike drill bits, end mills have hardened shanks, so I save 'em and make various tools by grinding. An angle grinder, die grinder, Dremel or Foredom with appropriate cutoff discs make quick work of cutting them to length, etc.
Cheers,
Frank Ford
Frank Ford
- tornitore45
Same here. I save any hard tool steel. Tap and even dies, I made a form tool out of a broken scissor blade. Too thin to be used flat but supported with a blank worked fine.
Mauro Gaetano
in Austin TX
in Austin TX
- warmstrong1955
Drill shanks make good pin punches for roll pins. I've made a bunch of 'em with old ones I saved.
Easy enough to machine a tip on, and hard enough not to mushroom, and not to brittle to fling little shards at you. Hold up better than 4140 Q&T.
I posted these before. Made these for a friend. The store bought models are wildly expensive.
I agree in many ways. The shanks and part of the flutes are reusable. Frank got it right about end mills. I've never had one spin to damage the shank.
Warmstrong. I probably commented on these already but it is worth knowing again. The way the ends are ground, they encapsulated the roll pin while driving it out. It is shrinking the diameter of the pin. It ain't no gasket punch.
Opps! You're right. Probably only works with HF drills.tornitore45 wrote: ↑Mon May 20, 2019 11:01 amNot HSS. Hardening HSS is a not a process available at the typical Home Shop Guy.you can fix that with a torch and bucket of water.
Conrad
