Best Hand-Held Tool for General Buffing?
SteveHGraham
Post by SteveHGraham » Fri Jul 05, 2019 4:34 pm
Now that I'm a great expert on bench buffers, I have a question.
It is unsafe to buff inside things with a bench buffer, so what's the best tool for that job?
I have an air buffer, which is more or less like an air die grinder. I'm not that thrilled with it. It works well, but my 17-CFM compressor can't keep up with it. I'm thinking maybe an electric die grinder is the best tool for the job.
BigDumbDinosaur
Re: Best Hand-Held Tool for General Buffing?
Post by BigDumbDinosaur » Fri Jul 05, 2019 10:50 pm
Buffing is a relatively low-speed operation. Die grinders typically turn at very high RPM and would, in my opinion, be wholly unsuitable for buffing.
I'm a caterwauling curmudgeon. What's your excuse? ☻
SteveHGraham
Post by SteveHGraham » Sat Jul 06, 2019 7:41 am
That's interesting, because my air buffer really flies. It seems to work better than a drill, which is slower.
I see that some die grinders have variable speed, and the buffing implements are fairly small, which would reduce surface speed.
