A few days ago, Lew mentioned the word billet. Then today, somebody posted on Facebook about a modification to their 3d printer and I couldn't help but lol!
New in town
- liveaboard
Re: New in town
What about brass?
Not as expensive as bronze, More expensive than stainless I guess, works easy, is heavy enough.
Stainless is hard stuff to work, and for this application hardness is not required.
Re: New in town
That isn't always the case. Here in the US, there are options that can be pursued when stainless is desired. Two of them I have considerable experience in machining, they being 303 and 416. 303 is available as 303 S, or 303 Se. The Se has an edge, as it machines slightly nicer, but the difference would be lost on someone without experience, so the S is good, and more readily available. This grade is not heat treatable and not recommended for welding.liveaboard wrote: ↑Sat Feb 29, 2020 4:47 am Stainless is hard stuff to work, and for this application hardness is not required.
416 is the nicest to machine, and is also heat treatable. It's a wonderful solution when a hardened part must be corrosion resistant and easy to machine prior to heat treatment.
