Hi
I am looking for a set of drawings for the Power Model Supply PWA-150 Westinghouse type 11” water pump in 1-1/2” scale. I have found the air pump drawings so all I need is the drawing for the water cylinder.
This pump is the big brother of the C.A. Street & Sons 9-1/2” 1-1/2” scale pumps.
Thanks
Tim
Power Model Supply 11” pump drawings wanted
Re: Power Model Supply 11” pump drawings wanted
I have the 8 drawings for the 3" steam air/water pump. There is a sheet 5W that has the water end drawings. I have no idea what prototype this is for. The prints are too big to scan but I can take an iPhone photo for you if you like. If you are looking for the single cylinder pump then I can't imagine that scale makes much difference. That is, you can calculate the dimensions required for the water section based on the plans you have.
I have the drawings for both water and air but have been cautioned that the dimensions for steam porting are not correct and have to be changed for the unit to run correctly
Yes.. I believe I have the sream porting changes as well.
If you want to email me directly i can send you photos of the drawings. Bshields at mehrs dot com
- Greg_Lewis
Bill:Bill Shields wrote: ↑Sun May 10, 2020 4:58 pm I have the drawings for both water and air but have been cautioned that the dimensions for steam porting are not correct and have to be changed for the unit to run correctly
Do you know if the drawing errors are also in the smaller pump Tim refers to above? Thanks.
Greg Lewis, Prop.
Unknown since I have not seen the drawings.
