What tooling have you made for your lathe?
jeffwithashack
Post by jeffwithashack »
How about showing off your cool tooling / measurement devices you have made for your lathe? Indicator holders, stops..... all the things you have made to make your lathe work easier. There are a lot of new people looking needing your expertise. Thanks!!!!
Greg B
Re: Show off your lathe projects
Post by Greg B »
Here is a few photos of my Trav-A-Dial bracket on my 12" Craftsman.
Enjoy, Greg B.
Jacin
Post by Jacin »
Best tool I ever put on my lathes Trav-A-Dials !!!!!
Greg B
Post by Greg B »
Here's a couple more.
Sticker to replace my worn out speed chart.
I know it's hard to see, but this is a replacement crossfeed dial that reads directly to diameter. In other words, dial in .001, it takes .001 .
Greg B.
Keith
Post by Keith »
This was one of the first projects I made after I got my lathe. Each division is .001 The long lines are .005 apart. I have since engraved numbers on it. Image
Keith, From the land of Oz, although not the Wizard of.
Greg B
Post by Greg B »
And yet a couple more.
Bijur oiler I picked up for $20.
And here is where it plumbs into the back of the saddle. It was alot of fun drilling 8" into the saddle and drilling small ports for the way lube squirt out under the carriage where it's needed. I never liked relying on just the felt wipers to adequately lubricate the ways.
Greg B.
Greg B
Post by Greg B »
And my faceplate that started life as a drill press table.
Mike_Burdick
Post by Mike_Burdick »
Greg,
All good looking and clever!
By the way, what's the sticker made with? Please elaborate a bit...
Greg B
Post by Greg B »
Thanks, Mike.
Actually, my wife drew up the sticker with ACAD in school. Clausing no longer sells the actual speedchart for the underneath drive 12" lathe, but I could buy a copy of a drawing. The drawing had all the pertinent info, such as font styles and point sizes. Armed with that, it was a simple matter for her to reproduce it in CAD. Then she printed it out on a sheet of adhesive paper with a color printer.
Greg B.
Mike_Burdick
Greg,
If you ever wanted to turn that sticker into a brass plate, you might be interested in this article:
http://www.gasenginemagazine.com/0403/0 ... ture1.html
Greg B
Post by Greg B »
Mike,
Interesting, and not to hijack this thread too badly, somewhat ironic, since the company I work for manufactures photolithographic and laser ablation equipment for the printed circut, silicon wafer and semiconductor industry.
Greg B.
JimGlass
Post by JimGlass »
Below is my homemade quick change tool post. It is my own design. The toolholders are tightened with a 1/4-20 screw. It worked great for 5 years but replaced it recently with an new AXA Aloris toolpost. I was able to still use all the toolholders that are also homemade.
Below is a combination cut-off and turn toolholder.
Jim
www.outbackmachineshop.com
