Bees in shop wall
Bees in shop wall
Any one had any luck getting rid of these pests. It is plain old honey bees? I have tried to kill them with CO2 but it didn't do the job, too much leakage probably. Would a hose to the exhaust of a gas engine do any good? I need ideas.
tia
re [/code]
tia
re [/code]
- Steve_in_Mich
Ideas that come to mind. Contact a bee keeper (if they are honey bees) they may come and take the whole swarm off your hands. Check bee keepers in the yellow pages. If that fails call the local fire department I would guess they have experience whith such matters.
I don't see that your engine exhaust wouldn't work - worth a try anyway. Toss in some mothballs too. I have no idea if mothballs will work or not but as long as you are experimenting, why not.
- Steve_in_Mich
- Flybynight
I have a big trouble with Wasps in my shop.
I just by some of the wasp killer.
Works great.
Might work on bees also.
Jim
Works great.
Jim
bees in wall
check with local bee keeper first!!!! make sure there not the south american species thats really AGGRESIVE!!!! those bees dont give up the chase and niose makes them madder than hell..... good luck
- steamin10
wasps
If they are honey bees they should be saved. if it is hornets/ wasps/ yellow jackets, getrid of em. A wet vac, with a little dish soap in a gallon of water is the answer. Plug it in, and use cheap sump pump hose to extend the business to wherever you need. Tape/ wire/ fix it to the area where the habitat hole is and turn it on about two hours before dusk, turn off at full dark. no chemicals, no fuss, just drowned pests.
A good swarm of honey bees are worth about 75 dollars now.
I had a freind who had real honey bees move into a garage wall, and fill two sections with honey comb alll summer long. In the fall, on a bright day, he would take down a sheet of plywood he had there for the purpose fo taking a lot of honey comb. he was able to do this for many years, getting about a hundred pound of bee soup and comb each year. I tried to get bees to do the same for me and could not. And once they were gone for him, they were gone.
Crude Solution
I drilled into the walls out around the periphery of the nest and filled the entire area with expanding foam insulation out of several aerosol cans.
Did it at night...damned the damn things in...they all died shortly thereafter...hive still there for all I know...that was years ago and I am not that interested to dig the wall out and look.
bees
Well the thread was most enjoyable.In perverse way since I had my share of bees and hornets.I look forward to many more such experience for that means the clock is still ticking.These are critters and it doesn't stop there Bill S. While the hive may be walled up there are other vermin who will seek this out.There can be an ant nest like crazy going on later with what's left.These ants will be even more of pest than the bees.
