Boring head taper attachment
Mike_W
Post by Mike_W » Thu Mar 23, 2006 3:10 pm
I made this for my Clausing. I used the end of a pushrod for the center. Since it is hollow, I put a grease fitting on the adapter that goes into the boring head.
Taper 1.12.jpg (42.62 KiB) Viewed 1764 times
torker
Post by torker » Thu Mar 23, 2006 8:56 pm
Arrrggghhh!!! I could have bought another boring head, the same size as the one I use on my mill. It went cheap on Ebay.
Thought "What on earth would I use it for".
I forgot all about using one on the lathe for tapers!
So Mike...what kind of pushrod end did you use. Looks a little bigger than the ones I have lol
Mike_W
Post by Mike_W » Thu Mar 23, 2006 9:24 pm
Torker, it is for a Ford 302.
torker
Post by torker » Fri Mar 24, 2006 7:34 am
Mike...Doh...ok I get it now. I thought the larger diameter piece behind the center was part of the pushrod.
Thanks!
