The tops of the pins are from old hinge pins, which I pressed into what used to be some long 3/8" bolts. The rest of the stuff is scrap as well. I was wanting to buy a new plastic handle, but found this wood one in a box of old files. I guess I'll have to sand and stain it. The steel part of the handle is from an old drill press spider handle. I welded it all up with a stick welder.
It bends well. I used a cheater bar on a piece of 3/8 rebar and bent that too, but it sort of scarred up my die. There is a piece in the pic of -almost- 1/2" aluminum round that I bent as well, though that would do well to have proper dies made for it, same with the 1/4" pipe. The other pieces in the pic are 1/4 drill rod and a 3/8" carriage bolt.
It can hold up to about a 5" die, should I ever find the stock to make larger ones, and 5/8" is the max width of the part to be bent. Right now, 1 1/2" is my biggest die.
Thanks for looking,
James
