New to me Cazeneuve HBX 360 Lathe
Moderators: Harold_V, GlennW
Re: New to me Cazeneuve HBX 360 Lathe
Post by BadDog » Fri Sep 02, 2016 12:45 am
That machine is fantastic, and I believe it has found it's proper home...
pete
Post by pete » Fri Sep 02, 2016 5:55 am
Sure have to agree with you Russ. Very, very nice work Patio.
Patio
Post by Patio » Fri Sep 02, 2016 4:58 pm
There is one major mistake with this design, anyone figure it out yet?
Harold you are disqualified from the test, as we have spoken about it, before I made the part. I had a brain fart and did not follow my own advise.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Post by spro » Sat Sep 03, 2016 1:44 am
I don't know what fault it was but if you were able to make one part on that machine to correct it, cool again. This is sort of a trip for me and I expect many others. At some point, somebody is going to see one of these machines and know more about them by your information. Others will be standing around clueless.
Patio
Post by Patio » Mon Sep 05, 2016 7:46 pm
The threaded part should have been done in a left hand thread. That way if the adapter ever tried to spin it would tighten the flange onto the adapter not try to unscrew it. It is glued into place so it should not move anyway.
Forgive the past!
Patio
Post by Patio » Mon May 21, 2018 1:43 am
I just received some new parts, for the lathe, from Cazeneuve.
This is an "Spindle Extension", with a lock nut and to locking buttons. It has an internal thread on the bottom end, where it connects to the lathe spindle.
And this is how they will assemble, on the left hand end of my spindle. The extension and the lock nuts are also used to set, the spindle's bearing preload. The actual spindle only runs, just beyond the left spindle bearing. The extension continues past the left edge of the cabinet, allowing any chips that enter the spindle, to leave the machine and not end up inside the cabinet.
I will get some pictures of the set up it has now, and the install of the spindle extension.
Forgive the past!
Patio
Post by Patio » Sat Jun 02, 2018 1:02 am
Hello everyone.
I am still progressing forward, between other projects.
I have installed the new Spindle extension.
I stand corrected on how they actually work with each other.
The nut, sets the spindle preload and is secured by one of the half moon keepers. The spindle extension is then threaded on to the end of the spindle, seating on a internal shoulder. It is then held into place with the other half moon keeper.
This is a picture of the spindle setup, made by the PO, when I bought it. The shiny aluminum part, is a plug I made for the end of the spindle, to keep the chips out of the motor cabinet.
These are the parts when removed.
The protruding part of the ring, was the load bearing section. The collar was made from the original nut and some round stock. The four set screws were tightened to set the preload.
Here is the new unit installed properly.
This is another mile stone in the life of this lathe. I am only the keeper of it, for the moment. Someday it will belong to another, and in better condition than when I acquired it.
I am still working on the control mechanism. That process can be seen in another thread on the board, starting on this page.
viewtopic.php?f=24&t=89632&start=360
That is it for now. It is summer time here in Washington state, meaning there is lots to do and get done, so things go more slowly on nonessential projects.
Take care of each other!
Forgive the past!
Patio
Post by Patio » Sat Jun 02, 2018 1:21 am
It just occurred to me, that you guys might like to see it with the cabinet closed! :D
Forgive the past!
Patio
Post by Patio » Sun Jun 03, 2018 7:49 pm
The cabinet door latch uses a 1/4" socket, to actuate the latch. I have been using a 1/4" drive ratchet, up to this point. I am going in and out of the cabinet enough lately, that I decided to make a dedicated handle for it.
Here is the results. The body is stainless and the handle is some form of mild steel.
It fits just snug enough to stay in place.
Still working on the speed controls. I have an new idea and have figure out where to mount the control. Now to draw it all up and see if it will work as planned.
Forgive the past!
Mr Ron
Post by Mr Ron » Mon Jun 04, 2018 5:57 pm
With such a nice lathe, I hope Patio is up to the task to use it well.
Mr.Ron from South Mississippi
Post by GlennW » Tue Jun 05, 2018 1:45 pm
Pat's got a real good grip on running it.
Patio
Post by Patio » Wed Jun 06, 2018 9:50 pm
When the controls are completed, I have a friend that has agreed to help me make some documentary type videos, of the lathe's many unique features, in operation. I will post them for all to see when made. I have not idea how long it will take to get to that point. I am drawing the new mechanism at this time, to see if it is viable setup.
Forgive the past!
