Turning the Scarlet Harlot into the Green Goddess
Marty_Knox
Post by Marty_Knox » Sat Nov 26, 2016 9:49 pm
In January 2016 I made a deal to acquire a 2.5" scale 4-6-0. Because of the red paint I dubbed it the 'Scarlet Harlot'. I thought I could do a little work, get it running good, then sell it. Well, things didn't work out quite that way. Here it is when I first got it.
Re: Turning the Scarlet Harlot into the Green Goddess
Post by NP317 » Sun Nov 27, 2016 10:49 am
And now?
Hudson Honey
Post by Hudson Honey » Sun Nov 27, 2016 11:21 am
AHHHHHHHHHHHHHHH.......please tell me it's gone. I still have nightmares about that thing.
Green is good......photos......we need photos.
Pamela
Marty_Knox
Post by Marty_Knox » Sun Nov 27, 2016 4:17 pm
Latest pictures, setting her on her wheels last Wednesday.
Marty_Knox
Post by Marty_Knox » Sun Nov 27, 2016 4:24 pm
First thing I decided was to paint her. Next was, the stack had to go! I have a pattern for a stack cap about the right size, so I had two cast in yellow brass.
Marty_Knox
Post by Marty_Knox » Sun Nov 27, 2016 4:28 pm
I went ahead and cut down the tender, taking 3" off the bottom. I was trying different shades of green at this point
Marty_Knox
Post by Marty_Knox » Sun Nov 27, 2016 4:46 pm
Here you go, Pam! Green!
Marty_Knox
Post by Marty_Knox » Thu Dec 08, 2016 11:11 am
Some pictures from today. The boiler and cab are just set on for now.
Soot n' Cinders
Post by Soot n' Cinders » Thu Dec 08, 2016 12:09 pm
Looks good Marty! Almost like one of the Tweetsie locomotives.
I don't know if it's just me, but that pilot looks a little long
-Tristan
Projects
Marty_Knox
Post by Marty_Knox » Thu Dec 08, 2016 12:23 pm
It's not just you, Tristan - it's long! I'm still not sure if I'm going to use it.
Fender
Post by Fender » Thu Dec 08, 2016 4:01 pm
Much improved tender ;-)
Dan Watson
Marty_Knox
Post by Marty_Knox » Sun Dec 11, 2016 12:49 pm
While the paint is the most prominent change, the mechanical work will make a greater difference. The left frame was 3/16" ahead of the right frame, the rocker boxes were mounted at an angle, and the drilled ports only had a tiny opening into the cylinders. I also modified the exhaust passages to separate them and give the proper turn. I milled away part of the solid saddle so I could use a Little Engines Pacific exhaust stand and blast pipe.
