Cheapo Harbor Freight Welding Table
Moderators: Harold_V, Scott
Re: Cheapo Harbor Freight Welding Table
Post by SteveHGraham » Sun Apr 23, 2017 6:21 pm
Today I finally messed up the plating on the table. I welded something which was clamped flat on the table, and the heat went through the part and melted some plating loose. Not a big deal, since the plating was going to come off eventually anyway.
dbstoo
Post by dbstoo » Mon Apr 24, 2017 12:06 am
The plating comes off easily. I was running some test beads in a 2" x 4" grid on a piece of scrap. When I finished I moved the scrap piece and found a 2x4 section of zinc peeled off. :)
Post by SteveHGraham » Mon Apr 24, 2017 10:21 am
I should remove the rest with acid to avoid the aggravation of watching it disintegrate over time.
