SMAW rods for boiler construction
jlakes85
Re: SMAW rods for boiler construction
Post by jlakes85 » Sun Aug 27, 2017 8:09 pm
Boiler builder,
Sounds good. Since XX10 doesn't have the ticking code clock associated with 7018's out of the oven or fresh can, I wonder why they aren't used for all passes on our boilers right off the bat?
jlakes85
Post by jlakes85 » Sun Aug 27, 2017 8:10 pm
Hi Marty,
Can you advise how hot you run the 1/8 Excalibur 7018 when doing stay bolts? My stays are 1/2 diameter and the sheet width is 5/16.
Regards,
John
Post by Harold_V » Mon Aug 28, 2017 1:53 am
I suspicion that the width reference is really the thickness, yes?
jlakes85
Post by jlakes85 » Mon Aug 28, 2017 5:58 am
Hi Harold,
That's correct..don't know where that word "width" came from..
Marty_Knox
Post by Marty_Knox » Mon Aug 28, 2017 3:33 pm
jlakes85 wrote:Hi Marty,
Regards,
John
No, John, I'd rather not. It's not the sort of thing you can learn from the internet. My advice would be to take some scraps of your plate, drill holes and countersink them, and practice on them. When you get one you're happy with, cut it in half and see how much penetration you got.
jlakes85
Post by jlakes85 » Sun Sep 03, 2017 1:47 pm
Hi Marty,
Sounds good. Does stuff like loctite navel jelly leave behind contaminants that would need to be rinsed out with acetone? There are a few joints coming up that I want to do via a backgouge process where I figured that the jelly would leave no doubt about reaching sound metal, but I am concerned about the potential to contaminate.
Regards,
-jlakes85
Marty_Knox
Post by Marty_Knox » Sun Sep 03, 2017 4:08 pm
I wouldn't use any chemicals near where I was going to weld!!!
There is no reason you should have to do anything more than grind to backchip.
