Steam operated cylinder drains?
DianneB
Post by DianneB » Sun Mar 04, 2018 9:58 am
Has anybody build the drains shown here? http://modelengineeringwebsite.com/Drain_cocks.html
Do they work well? Any "tweaks" to improve the design?
Re: Steam operated cylinder drains?
Post by NP317 » Sun Mar 04, 2018 11:02 am
I have a commercial set like that on my Ten Wheeler, plumbed differently. They have worked perfectly for years.
I did plumb them so there is a drain plug between each set/cylinder, accessible from the outside, below each cylinder.
When finished with an operating session, I remove the plugs and blow the water out of the system with compressed air in the boiler.
Highiron
Post by Highiron » Sun Mar 04, 2018 9:34 pm
These are the cylinder cocks that little engines has been making and selling since the 1960s I have them in stock ready to run at $100 a set of four plus shipping
Joe Tanski
Post by Joe Tanski » Mon Mar 05, 2018 9:36 am
what thickness (Teflon) PTFE sheet do you guys use in these cylinder cocks.I have two sets of these one on my 4-6-0 1 1/2,one set on my 1" little engine atlantic.
I have tried to use 1/32" (.0313 )thickness Teflon white and can only get 4-5 hours of use on the cylinder cocks before the Teflon
sheet deforms and two dimples form. when the steam is turned off they will not open
Joe
Post by NP317 » Mon Mar 05, 2018 11:30 am
Joe: I think mine use thin hard brass sheet instead of Teflon sheet.
Mike: I PM'd the Original Poster info about the cylinder cocks still listed in your catalog.
DianneB
Post by DianneB » Mon Mar 05, 2018 12:23 pm
Unfortunately my cylinders were tapped 1/4-28 for the drains. Don't know if I want to re-tap them ......
Post by Harold_V » Mon Mar 05, 2018 4:02 pm
I can't address the proper material, but I can assure you that using Teflon is most likely not proper. It cold flows, and will do so regardless of the thickness you choose. I'm interested in hearing what does work, though. :wink:
Post by Bill Shields » Mon Mar 05, 2018 9:39 pm
I had the same problem with VIRGIN PTFE in that application, but it works like a charm with fiber filled PTFE...
DianneB
Post by DianneB » Tue Mar 06, 2018 6:54 am
Thanks for the discussion folks; it was very informative. After careful research and deliberation I decided to overhaul and modify my existing steam-operated drains. I don't know who made them but I managed to reduce the height, re-packed the pistons so they move more freely and hopefully don't stick in the future.
